November 23, 2024, 07:45:42 pm *
Author Topic: GiveAway of the Day - WireKeys  (Read 9561 times)
« on: July 26, 2008, 12:09:44 pm »
Guys,
I bumped into this one today : http://www.giveawayoftheday.com/
Since this (see below screenshot) is free for the next 21 or so hours, I downloaded and installed it, with the thought that maybe this would be a good tool for the near future and remote control stuff.
The tool itself (at a glance) looks promising, but currently I don't know (and can't know) where it will be a good thing for XXHighEnd, and whether I can't do similar stuff myself (note though that it seems to be loaded with system info stuff, which always might come off handy).
Just in case, and since it is free today, install it and get a key yourself.
Note : the procedure is completely vague to me, and the .txt which comes along with it seems to talk about sending an email, while no email address can be found. Instead, I think you must start WireKeys from the tray icon that will be there, and enter the info from the .txt in the screen under the option "registration" at the bottom. That seemed to work, but from here I don't know. Will I receive an email ? do I need another key ? where to enter that ? is it already activated ?
The vagueness IMO comes from the other instance "Giveaway of the Day" which is in between now.
Btw, somewhere I found that the key (??) will be received withij 48 hours. So let's see what happens.
If you want to go for this, be sure to do it within 21 hours from the time of this post.
« Reply #1 on: August 01, 2008, 12:05:31 am »
Well I did this the other day when still valid... but it says it is unregistered still.  I couldn't find an email to send it off to.... probably that is why; they maybe buried the email somewhere?  anyway, from what I read, the "free" registration did not include new versions.
« Reply #2 on: August 01, 2008, 12:14:55 am »
The latter is true, and the first as well with me. shout
I'm sorry that I have disturbed you with this on-sense.
