April 02, 2025, 09:43:26 am *
Pages: 1 2 3 4 5 [6] 7 8  All
Author Topic: How I tweaked my Vista virtually dead (also for W7)  (Read 196439 times)
« Reply #75 on: August 21, 2009, 10:30:00 pm »
Yes Telstar look in to that please,
you have dedicated machine now.
I will when i'll come back from the vacations.
I can say that even with those 3-4 extra services my pc is already as dead as Peter's.
I wont remove trustedinstaller, but i think that it can be a leftover of some program install that went not too well. Vista/w7 are very easy to screw up the installer.
I check the event log (the stuff that is not disabled lol) for errors after each important update/install/driver/change. There mustnt be errorrs.
But i'm afraid that i'll have to rollback to vista to be able to use the VFD/remote unhappy
« Reply #76 on: August 21, 2009, 10:35:06 pm »
Themes and UxSms.
What UxSms does? Do you know the full service name in english?
I just put vista basic theme (not sure about SQ improvements) and stretched wallpaper and the cover art shows fine (thanks Roy for the tip). i also found the perfect size to fit most of the screen is 660px.
« Reply #77 on: August 21, 2009, 11:45:54 pm »
Desktop Windows (Session) Manager. http://en.wikipedia.org/wiki/Desktop_Window_Manager
Go figure ...
« Reply #78 on: August 22, 2009, 12:59:18 am »
there is one thing more in W7, I guess.
the .etl one
« Reply #79 on: August 22, 2009, 05:10:08 am »
http://www.vistax64.com/vista-security/68952-wfpdiag-etl-what.html
Just stop downloading. Happy
ivo
Music lover
View Profile WWW
« Reply #80 on: October 30, 2009, 12:55:46 am »
In case someone needs it:
http://www.speedyvista.com/services.php
rankena
« Reply #81 on: December 22, 2009, 10:41:01 pm »
XXHEVistaTweaks.bat-can it be used with XpSp3?Sorry for my bad english unhappy
« Reply #82 on: December 23, 2009, 12:13:31 am »
I guess nobody will know because nobody will have tried. But :
Also it isn't needed ! Remember, the tweaks (at least mine from the beginning of the topic) are to reduce all the IO which XP hasn't to begin with. So for XP it is fine to leave this out.
rankena
« Reply #83 on: December 23, 2009, 10:13:55 am »
Never mind,i very reduce XPSp3  resource eating using others tweaks and manual settings compared with standart XpSp3. PS.very good site for me"beginner sick audiophile" love this
« Last Edit: December 24, 2009, 10:40:38 am by rankena » Logged
« Reply #84 on: February 17, 2010, 06:46:52 pm »
To come back on those remaining services, on the resource monitor.
What about setting up SSD in FAT32 mode ??
I have read its much faster, and there is less I/O going on.
But there are disadvantages too, like max filesize and max amount of files in folder etc.
But we don't use large files and just create a smaller partition.
Could this be an option ???
My W7 expires in 14 days, so have to do a new setup anyway.
Maybe I will create some partions and test different OS. (XP,Vista and W7)
« Reply #85 on: February 17, 2010, 07:03:11 pm »
...... so have to do a new setup anyway.
Don't forget to check the firmware of your solid state! This is your change to update I think!
Johan
« Reply #86 on: February 17, 2010, 07:07:41 pm »
Johan
Thnx Johan,
Offcourse I will
I believe 1.42 Beta is out (maybe the final)(Currrently on 1.30)
I have 2 weeks to make things happen,
Could use this opp to do some OS testing too!
Roy
« Reply #87 on: February 17, 2010, 08:52:11 pm »
QUOTE:
NTFS is a journaling file system, that is, before it makes any changes to a file,
it first writes out a journal entry. Once the data is successfully written out,
it marks the journal entry as complete. That way if the computer crashes in the middle of changing a file,
it can examine the journal and restore the file to it's original state. But this increases the number of writes to the SSD,
which will both slow it down and decrease its overall lifespan.
The FAT file systems do not use journaling and thus will operate a bit faster than NTFS on an SSD and the drive will last a bit longer.
NTFS does offer a number of other features that probably offset the speed difference. In addition to the journaling,
which will reduce the need for a chkdsk after a crash, you also get compression, encryption and file permissions.
If you need raw speed for whatever reason, FAT32 is the way to go. Otherwise, NTFS is likely better
END QUOTE
This will most likely terminate the next services:
C:\$Mft (NTFS0-MFT (Master File Table)
C:\$LogFile (NTFS-volume log)
Roy
http://www.ntfs.com/ntfs_vs_fat.htm
PS: Nice thing though is if you do format with Fat32, you can always convert to NTFS later, but not vice versa
« Reply #88 on: February 17, 2010, 09:23:45 pm »
And for NTFS, did we already mentioned this one ?
http://www.tomstricks.com/how-to-disable-the-ntfs-last-access-time-stamp-in-windows-vista-or-in-xp/
Marcin_gps
« Reply #89 on: March 06, 2010, 10:58:23 am »
Did anyone try tweaking systemresponsiveness value in regedit?
If SystemResponsiveness is set to 100 (default in Server 2008), it means that all processes are given a higher priority than multimedia. In Windows Vista the default value is 20.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile]
"SystemResponsiveness"=dword:00000014
