April 02, 2025, 10:07:06 am *
Pages: 1 2 [3] 4 5 6 7 8  All
Author Topic: How I tweaked my Vista virtually dead (also for W7)  (Read 196459 times)
leifchristensen
« Reply #30 on: October 30, 2008, 11:14:05 am »
P:what about getting an English version of Vista; a lot of your "clients" are english-speaking and the forum language is english too. Happy
imo
best
Leif
Oslo
« Reply #31 on: October 30, 2008, 10:04:15 pm »
200% agreed. Sadly I started off in dutch, and I don't think there is a way to upgrade to english.
Reinstal from the beginning would take me x days of installing the development environment, which is just necessary here.
But again, 200% agreed. aggressive
andy74
« Reply #32 on: October 31, 2008, 08:21:00 am »
you might want to consider this link
http://www.tipandtrick.net/2008/windows-vista-sp1-32-bit-mui-language-packs-direct-download-links/
there is an english language pack for vista ultimate.
Andrey
« Reply #33 on: October 31, 2008, 08:41:36 am »
Hey, I didn't know that ! This is great ...
Thanks Andrey.
LydMekk
« Reply #34 on: November 08, 2008, 12:57:55 am »
Yup, there's no problem in adding another menu language afterwards in Vista through Windows Update. I can install like 20 different ones and easily change between them with a reboot afterwards.
« Reply #35 on: November 16, 2008, 07:00:20 pm »
The below can be reached by Manage like in the before post. I think you can recognize by means of the icons where to go.
With the first one (14c) I could not prove that it really helped, but the intention with this one is to make the system at rest earlier after a boot. My Vista for sure is, but I don't know whether this one cause it.
Please note that this kind of "weak" one, actually had to be a full stop of Event Logging, but I don't think it can be done. This is about the one above this one (look at the right) which is similar but for normal operation. The one here (14c) is only for during startup.
14d u/i 14f speak for themselves.
I was not able to stop the Dialog log... it gives me an error "Access denied" when I tried (on both the SSD and HDD).  Also, after a reboot, these other two logs start up again, right?  Do you shut them down each time?  I'm going to go look again this morning.
« Reply #36 on: November 16, 2008, 07:07:02 pm »
Am i doing something wrong? Reghack14f.png in your post say's that i have to stop below pic? But when i do that you will see the error down below.
oh ya, this is what I get too... only in english.  And, after a reboot, all logs are running again; so, the NTFS and Rdr logs start up again. ohwellz or doing something wrong?
« Reply #37 on: November 16, 2008, 07:12:39 pm »
I was not able to stop the Dialog log... it gives me an error when I tried (on both the SSD and HDD).  Also, after a reboot, these other two logs start up again, right?  Do you shut them down each time?  I'm going to go look again this morning.
No, I don't shut off anything manually.
I'm stuck with the 5 showing in the very first post of this topic. I just don't know what to stop and how to stop it. Not by some hack and not even manually.
« Reply #38 on: November 16, 2008, 07:15:39 pm »
I can't tell why this doesn't work for you (or for Gerard for that matter). Note that it mind be kind of importantish though, because what's left for me (see 2nd picture of first post in this topic) stays away between 6-12 minutes. I don't know (anymore) about the frequency of things you got left. Could be each 10 seconds ... (but you can look for yourself with the resource monitor).
« Reply #39 on: November 22, 2008, 01:33:36 pm »
Andrey
Ok, just done it. Upgraded to SP1 and installed English as an additional language.
Works like a charm.
Again thanks for the tip Andrey.
tricka
« Reply #40 on: March 26, 2009, 05:03:02 am »
thank you for this thread...really nice.
« Reply #41 on: June 18, 2009, 08:49:15 am »
Have that problem also
after reboot all logs startup again
Could this be the BIOS that does that?
grtz
« Reply #42 on: June 18, 2009, 02:08:08 pm »
maybe there is a way to shut of some logging
untick 'enabled'
see pic
Peter, are those logs being used by Vista, don't think you can turn 'm all off.
Still trying
« Reply #43 on: June 18, 2009, 02:38:17 pm »
Hmm ... I never tried that one.
Remember, I have only a few I/O's once per 3-8 minutes as explained elsewhere in this topic, and if this eliminates those too, you are there.
But I think you have more than those few I have, so with this you may want to deal with those others ? ... I can't check that, because I already don't have those.
scratching
« Reply #44 on: June 18, 2009, 02:45:49 pm »
Oke, they stay off after reboot,so
Will illiminate them step by step
will see Grin
