andy74
« Reply #15 on: October 28, 2008, 04:29:45 pm » |
Hi, Here are the attempts to make reg and bat files to do the above tweaks automatically. If some of the commands fail you will need to do the tweaks manually as described before. Turning off drive indexing you still need to do manually. reg file: Windows Registry Editor Version 5.00 ;[START] XXHE Vista Ultimate Services
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction] "Enable"="N"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters] "EnablePrefetcher"=dword:00000000
;Application Information [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Appinfo] "Start"=dword:00000003
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Reliability] "TimeStampInterval"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Defender] "DisableAntiSpyware"=dword:00000001
bat file: REM Tablet PC Input Service sc config TabletInputService start= disabled
REM Windows Image Acquisition (WIA) sc config stisvc start= disabled
REM Windows Defender sc config WinDefend start= demand
REM Print Spooler sc config Spooler start= disabled
REM Security Center sc config wscsvc start= demand
REM Superfetch sc config SysMain start= disabled
REM ReadyBoost sc config EMDMgmt start= auto
REM Windows Search sc config Wsearch start= disabled
wevtutil.exe sl Microsoft-Windows-Diagnosis-DPS/Operational /e:false wevtutil.exe sl Microsoft-Windows-Diagnostics-Performance/Operational /e:false wevtutil.exe sl Microsoft-Windows-GroupPolicy/Operational /e:false wevtutil.exe sl Microsoft-Windows-ReadyBoost/Operational /e:false wevtutil.exe sl Microsoft-Windows-ReliabilityAnalysisComponent/Operational /e:false wevtutil.exe sl Microsoft-Windows-TaskScheduler/Operational /e:false
logman update trace "EventLog-System" -ets -max 33 logman stop -n "DiagLog" -ets logman stop -n "NtfsLog" -ets logman stop -n "RdrLog" -ets
pause
Hope it helps Andrey
1. USB FreeAgent 500Gb -> P4 2.8 2gb RAM Vista Ult -> XXHE Q1=14 prio both = Normal -> esi juli@ (SPDIF is default device->analog mon in ESI panel->analog outs) -> nad 320BEE->Boston Acoustics cr150 3. IBM thinkpad r52->VIsta Ult XXHE, Unattended playerprio=Nothing threadPrio=Normal -> very cheap usb audio adapter -> shure attenuator -> headphones shure 210
« Reply #16 on: October 28, 2008, 04:52:08 pm » |
Hi Andy,
Can you please tell how to make this work/to do this. I do not have a lot experience with these kind of things..
Thanx!!
andy74
« Reply #17 on: October 28, 2008, 05:25:29 pm » |
Hi Gerard,
Sure, no problem.
open notepad copy reg file code to the new notepad window save as XXHETweaks.reg on disk close notepad double click on the file in the windows explorer answer yes to the questions It should report success in the end
open notepad, again copy bat file code to the new notepad window save as XXHETweaks.bat on disk double click on the file in the windows explorer answer yes to the questions It will show cmd line window and pause at the end of execution of the commands.
Edit: To run the files you may need to right click on the files above and run them as Administrator
Please let me know if you need more info Andrey
« Reply #18 on: October 28, 2008, 07:46:03 pm » |
Andrey Thanx.... when i get home home i will give it a try... Does this mean that i will exe it once? Or do i have to do it everytime with a reboot.
« Reply #19 on: October 28, 2008, 10:54:50 pm » |
Andrey, These are the errors i get.  I see Ultimate in your writing. Is it the same with my Vista? And do you understand the first error or do i need to translate. Thanx
andy74
« Reply #20 on: October 29, 2008, 09:47:15 am » |
Gerard,
this is all expected behaviour.
First error message is because the last registry key in the reg file won't work. So you need to disable windows defender manually as Peter described. I will delete this key from reg file in the above post.
the other errors about Access denied are also expected. So you need to turn off those data collectors manually again.
The main idea is to do automatically as much as possible, the rest (that give errors) must be done manually.
I am going to update those code snippets.
« Reply #21 on: October 29, 2008, 10:25:42 am » |
Thank you for your efforts on this Andrey. Really nice. Maybe it is not clear for everybody what to do when what "error" appears, and I think for me also will count that when I just apply the file without knowing the history of this topic (the manual settings) I wouldn't know what manual settings to go to. A bit of a stupid situation you can't help of course. I sure won't require anything else from you, but what if each error would show a link somehow to the manual setting in this topic ? Or, because a clickable link won't work, maybe a reference to the subject/picture concerned, like : RegHack04.png.
« Reply #22 on: October 29, 2008, 11:04:41 am » |
Andrey, Can you like Peter asked tell what to shut off maually and tell how i get to tab Services. I cant find that. With services i mean the manualy explaning that Peter did like reghack05.png Thank you and sorry for the trouble......
« Reply #23 on: October 29, 2008, 11:23:36 am » |
Andrey You told me that windows defender is not shut off. But when i like to start defender is says that it is shut off...
andy74
« Reply #24 on: October 29, 2008, 12:24:46 pm » |
Thank you for the comments and sorry to have confused you with this. As always - best intentions lead ..... somewhere else  Yes I will do as Peter asked. But I need time to make it more human friendly this time. Andrey
« Reply #25 on: October 29, 2008, 12:31:25 pm » |
Andrey Take your time.... There is no real problem here.... Pc still up and running....
andy74
« Reply #26 on: October 29, 2008, 03:15:20 pm » |
Ok here is next attempt: Save it to a single file XXHETweaks.bat and run it. It includes registry changes inside. Upon complettion it should say something like: Making registry changes... Stopping services... [SC] ChangeServiceConfig SUCCESS [SC] ChangeServiceConfig SUCCESS [SC] ChangeServiceConfig SUCCESS [SC] ChangeServiceConfig SUCCESS [SC] ChangeServiceConfig SUCCESS [SC] ChangeServiceConfig SUCCESS [SC] ChangeServiceConfig SUCCESS [SC] ChangeServiceConfig SUCCESS turning off logs under "On to the Log files !"... DONE! !!! The followings things you need to do manually !!!: The names in "" are of the posts from this topic http://www.phasure.com/index.php?topic=548.01. turn off drive indexing under "Shut Off Indexing REALLY"... 2. turn off Defragmentation under "Defrag brrrr"... 2. turn off logs under "Another group of Logs"... THE END Press any key to continue . . . I also attached bat file for your convenience @ECHO off
ECHO Making registry changes...
REM creating a registry file ECHO Windows Registry Editor Version 5.00 > XXHEVistaDead1.reg ECHO ;[START] XXHE Vista Services >> XXHEVistaDead1.reg ECHO.>> XXHEVistaDead1.reg
ECHO [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction] >> XXHEVistaDead1.reg ECHO "Enable"="N" >> XXHEVistaDead1.reg ECHO.>> XXHEVistaDead1.reg
ECHO [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters] >> XXHEVistaDead1.reg ECHO "EnablePrefetcher"=dword:00000000 >> XXHEVistaDead1.reg ECHO.>> XXHEVistaDead1.reg
ECHO ;Application Information >> XXHEVistaDead1.reg ECHO [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Appinfo] >> XXHEVistaDead1.reg ECHO "Start"=dword:00000003 >> XXHEVistaDead1.reg ECHO.>> XXHEVistaDead1.reg
ECHO [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Reliability] >> XXHEVistaDead1.reg ECHO "TimeStampInterval"=dword:00000000 >> XXHEVistaDead1.reg ECHO.>> XXHEVistaDead1.reg
ECHO [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows Defender] >> XXHEVistaDead1.reg ECHO "DisableAntiSpyware"=dword:00000001 >> XXHEVistaDead1.reg ECHO.>> XXHEVistaDead1.reg
REM executing the registry file XXHEVistaDead1.reg
REM deleting the registry file del XXHEVistaDead1.reg ECHO. ECHO.
ECHO Stopping services... REM Tablet PC Input Service sc config TabletInputService start= disabled
REM Windows Search sc config Wsearch start= disabled ECHO. ECHO.
ECHO turning off logs under "On to the Log files !"...
wevtutil.exe sl Microsoft-Windows-Diagnosis-DPS/Operational /e:false wevtutil.exe sl Microsoft-Windows-Diagnostics-Performance/Operational /e:false wevtutil.exe sl Microsoft-Windows-GroupPolicy/Operational /e:false wevtutil.exe sl Microsoft-Windows-ReadyBoost/Operational /e:false wevtutil.exe sl Microsoft-Windows-ReliabilityAnalysisComponent/Operational /e:false wevtutil.exe sl Microsoft-Windows-TaskScheduler/Operational /e:false ECHO. ECHO DONE! ECHO. ECHO.
ECHO !!! The followings things you need to do manually !!!: ECHO The names in "" are of the posts from this topic ECHO http://www.phasure.com/index.php?topic=548.0 ECHO. ECHO 1. turn off drive indexing under "Shut Off Indexing REALLY"... ECHO 2. turn off Defragmentation under "Defrag brrrr"... ECHO 2. turn off logs under "Another group of Logs"... ECHO. ECHO.
REM these are "Another group of Logs" not working for now. May be someone will figure it out.
REM logman update trace "EventLog-System" -ets -max 33 REM logman stop -n "DiagLog" -ets REM logman stop -n "NtfsLog" -ets REM logman stop -n "RdrLog" -ets REM ECHO. REM ECHO.
ECHO THE END
pause
« Reply #27 on: October 29, 2008, 05:46:16 pm » |
Andrey, great thanks on behalf of everyone who is going to benefit from this ! Peter
« Reply #28 on: October 29, 2008, 10:10:10 pm » |
Andrey 1000 time's  These are the message's in dutch... again thanx for the time.... Gerard
« Reply #29 on: October 30, 2008, 10:08:01 am » |
Peter Am i doing something wrong? Reghack14f.png in your post say's that i have to stop below pic? But when i do that you will see the error down below.
