November 24, 2024, 04:44:49 am *
Author Topic: XXHighEnd Model 0.9u-16 (solves bugs for Track Load Optimization)  (Read 7943 times)
« on: May 22, 2008, 10:52:37 pm »
0.9u-15 introduced some bugs which have been solved as per this version (all Engine#3) :
  • A before Playlist being longer than the current one, now doesn't start playing the remainder of tracks from that curent one (e.g. track 13 of a before Playlist started playing after all 12 tracks from the current one had been played).
  • Pressing Next (or Prev at Attended Playback) continued at the timer cursor porsition of a track playing before Next (Prev) was pressed.
  • Ditto when the Playlist was cleared (Clear button) and Play was pressed for the first track to play.
    On this topic as well as the previous one, probably variations can be found not working as logically as you want.
  • The Invert Checkbox was grayed out, and Invert could not be used.
  • As it appeared, another variation of (non standard) WAV headers can exists, as exhibited by the Nin website (http://theslip.nin.com/, 96/24). They too, now play.
* XXHighEnd-09u-16.zip (1995.88 KB - downloaded 780 times.)
Page created in 0.493 seconds with 19 queries.
