November 23, 2024, 12:24:30 pm *
Author Topic: Vista SP1  (Read 24842 times)
« on: April 17, 2008, 11:16:06 am »
Hi All,
I am a little scared trying...But has anyone tried SP1 dutch version??  dntknw It is available....  blink
hybride
« Reply #1 on: April 17, 2008, 11:34:01 am »
Does the lanquage matter?
I installed SP1 RTM (english) more then a month ago and i only can say that it optimized things.
Asus-VM-htpc&1TB>EMU1212M>Stello 220MKII DAC>UCD180HXR>Focal1037BE
« Reply #2 on: April 17, 2008, 11:36:33 am »
Well i read that the dutch version already contains more solved bugs.... I think i will give it a go.... Can always go back...
« Reply #3 on: April 17, 2008, 12:42:31 pm »
Hi Gerard,
I put the dutch version yesterday, no problems so far!
Gerard.
« Reply #4 on: April 17, 2008, 01:14:29 pm »
Hi Gerard,
Gerard.
Thank you!  Happy I hope it will not give problems here too.
Music pc is downloading it....  Happy
« Reply #5 on: April 17, 2008, 03:07:27 pm »
Wow without any problems...      Happy
« Reply #6 on: April 17, 2008, 03:14:34 pm »
Any improvements?
Johan
« Reply #7 on: April 17, 2008, 03:24:25 pm »
Any improvements?
Johan
Hi Johan,
I have the idear that removing/moving/copying is a bit faster... For the rest i did not find out yet...
Gerard...  Happy
Eric
« Reply #8 on: April 17, 2008, 08:49:08 pm »
Where can I get the Dutch SP1 ?
Eric
« Reply #9 on: April 17, 2008, 09:13:28 pm »
Eric
Here it is..... Good Luck....
http://www.update.microsoft.com/windowsupdate/v6/vistadefault.aspx?ln=nl
« Reply #10 on: April 19, 2008, 10:46:20 am »
Yesterday i have installed Vista SP1.......it became a disaster. Many hiccups and cracks in the sound. CPU usage for both 65% during use of XX. Strange mouse behavour, shaking, busy indicater. I suppose the system is doing something more, but what? After a de-installion of SP1, all became 'normal'.heat I now only hear sometimes cracks and hiccups on mine new soundcard.
Johan
« Reply #11 on: April 19, 2008, 11:14:51 am »
Hi Johan,
How long did you wait after startup to start XX?
On my systen I first have to wait for the lsass.exe-proces to finish with all its disk-IO.
After that XX works OK.
I have no idea if this lsass-thing is necessary or can be shut off.
After installing SP1 the system took some time doing it's own thing too.
Maybe this happened to you?
« Reply #12 on: April 19, 2008, 11:19:51 am »
lsass is the most nasty thing for I/O's you don't want. So far I would not know how to shut that off (for its I/O's), althoug I dove into that for a couple of hours only, a while ago), and I was hoping that just this went away with SP1.
When you kill lsass, your PC will reboot ...
« Reply #13 on: April 19, 2008, 12:44:40 pm »
When i had the impression all things were finished i started XX! a few minutes! I suppose you checked your taskmanager too see the progress of the lsass.exe-proces. How long did you wait?
I rebooted the system several times, but nothing changed.
Johan
« Reply #14 on: April 19, 2008, 01:08:59 pm »
Johan
That doesnt sound good.  unhappy
I can say that untill now it was almost faultless... Only my virusscanner does not update automatic anymore.
Succes
