electrosound
« on: June 08, 2007, 07:06:17 pm » |
Ludvig Berghe Trio
This is a very nice recorded CD and nice jazz music (hard to find for me coming the two together) With XX I hear now how good it is recorded The guy's use 2 handmade Didrik de Geer microphones direct to two track digital master and no funny sh*t involved (there words not mine) and you hear that that's for sure
I want to share a piece of a track (let's say the half of a track) , but how do I do that there is only 500KB to attach
Marco
Toshiba Satellite Pro, 500Mb memory, XP => USB => PCM2707 USB converter => DIY 2X TDA1541 Crown => CCS Tube output => SE 300b => DIY horns with MD3 for mid high, Beyma G350 for mid low
« Reply #1 on: June 08, 2007, 07:35:27 pm » |
Haha, that's a good one. Wasn't quite prepared yet.  But half of a track ... maybe then the rights people are at my doorstep too soon ... I'd say 1/3 of a track max, and no more than 2 minutes (which would be some 20MB uncompressed, but I highered the limit to that a somewhat for conveniency). Note that the up and down speed of this server is 1000kbs only (that's some 100 kilobyte per second  ). With XX I hear now how good it is recorded Please keep in mind that this board is intended to be about "difficult" music, not turning out to be difficult with XX at all. It's close, but just okay. It would be better if you'd add where things normally go wrong(ish), and not anymore now. Also, in a later stage it would be about examples where a new XX version has improved ... or got worse for that matter. I'll listen, try, and try to improve again.  Under those conditions I think it is very legit to post samples.
electrosound
« Reply #2 on: June 09, 2007, 12:19:14 am » |
Haha, that's a good one. Wasn't quite prepared yet.  I see now some more zero's to attach  But half of a track ... maybe then the rights people are at my doorstep too soon ... I'd say 1/3 of a track max, and no more than 2 minutes (which would be some 20MB uncompressed, but I highered the limit to that a somewhat for conveniency). I don't want you get in trouble, I ripped 1/3 of the track Please keep in mind that this board is intended to be about "difficult" music, not turning out to be difficult with XX at all. It's close, but just okay. It would be better if you'd add where things normally go wrong(ish), and not anymore now. Ok I see your point here, than it is more to follow from what is going on, if that is what you mean?? Also, in a later stage it would be about examples where a new XX version has improved ... or got worse for that matter. I'll listen, try, and try to improve again.  Under those conditions I think it is very legit to post samples. Hahaha I understand you, I hope that the think about it the same way  I can't attach the file, I have try it at least 5 times now  it is quitting suddenly Marco
« Reply #3 on: June 09, 2007, 03:20:04 am » |
Hmm ... this doesn't seem to work. It looks like some 8MB is the maximum (the 19MB was my attempt). I guess it wasn't made for this ... Must investigate this further ...
electrosound
« Reply #4 on: June 09, 2007, 12:36:44 pm » |
That is what I thought to, the uploading was stopped before the half, the track is 20Mb so it must be somewhere near 8Mb Ok I wait, or make it shorter...... Marco
« Reply #5 on: June 12, 2007, 03:26:56 pm » |
Okay ... there was some internal limit of 2MB. If everything is allright you can do 25MB now (but you should do not more than some 20MB  ).
electrosound
« Reply #6 on: June 12, 2007, 07:38:36 pm » |
Okay ... there was some internal limit of 2MB. If everything is allright you can do 25MB now (but you should do not more than some 20MB  ). Hi Peter, Sorry, but it stopped again, the track is 19,9MB Marco
« Reply #7 on: June 12, 2007, 10:50:10 pm » |
Uh-oh ... Today I tested it with a high speed connection ... wrong. Now it times out. This just isn't made for this. Must find something else.
electrosound
« Reply #8 on: June 12, 2007, 11:16:20 pm » |
Uh-oh ... Today I tested it with a high speed connection ... wrong. Now it times out. This just isn't made for this. Must find something else.  Hahaha you must be at high speed then yes, if I count the time that I was on Well take your time, you don't have to rush for me  I'll see when it's ok
« Reply #9 on: June 13, 2007, 10:15:43 am » |
Hi Marco,
Could you please try it once more ? Currently I can't because I'm too near to that server, and 20MB goes in 1 second ...
If you can do it before 5 hours from now (watch the posting time), we can adjust things before people go home here (and otherwise it will be tomorrow, which is okay with me). Thank you !
electrosound
« Reply #10 on: June 13, 2007, 01:45:09 pm » |
Hi Peter, 20MB in one second, that is one deep breath I tried it (and within time) and I was almost there, I think that it came near 90% But if you want me to try again that's ok, and more than again is also fine with me Marco
« Reply #11 on: June 13, 2007, 03:36:18 pm » |
Marco, do you recall the message om the screen ? or did it just stop ?
It should work now though ... I go home in a few minutes, and then I will try again myself.
electrosound
« Reply #12 on: June 13, 2007, 06:01:53 pm » |
Marco, do you recall the message om the screen ? or did it just stop ? I get a message in my browser say the server is to busy or there are network problems (something like that I cant remember the precise words) and then there is the choice button to try again I didn't press try again because I did that last week and I now that he starts all over again It should work now though ... I go home in a few minutes, and then I will try again myself.
ok I will try to
« Reply #13 on: June 13, 2007, 06:06:47 pm » |
It works with me (at a download speed of 3000kbs or so (and upload overthere is 1000)).
It took 5 minutes or so.
electrosound
« Reply #14 on: June 13, 2007, 07:20:40 pm » |
Well I think that it works
