November 23, 2024, 03:21:48 pm *
Author Topic: u10 vs. u8  (Read 28052 times)
LydMekk
« on: April 01, 2008, 02:24:24 am »
Have swapped between these two around 10 times now. Can't really show any big differences in my setup, maybe a LITTLE more impact in the bass in u8?
Maybe u10 sound a little more clinical?
Or, is it me who's off my game?
Any other views? Using UpsampleON, Noinvert, 0db and Q=14. ProSch-3. 44/16 material, WAV only.
LydMekk
« Reply #1 on: April 01, 2008, 02:34:42 am »
Hm, nah, not sure there's much difference.
Will test some more.
Mani, any thoughts?
andy74
« Reply #2 on: April 01, 2008, 07:25:03 am »
To me u8 sounds better/smother.
u10 gives me a "headache" of mine again.
But I seem to be alone in what I hear/feel. So don't think it is important anymore to others.
« Reply #3 on: April 01, 2008, 07:31:34 am »
Are you crazy ? to me it is ...
« Reply #4 on: April 01, 2008, 08:54:00 am »
Andrey, can you tell at which settings you do this comparison ?
And can you describe for a simple soul like me i.e. in for me audible terms what you hear (as differences) ?
I assume you compare Unattended only ?
Lastly, wouldn't it be better for you to play with the Mem box checked ? (but first look whether it makes a difference at all, which you can see by the memory useage).
hybride
« Reply #5 on: April 01, 2008, 09:07:04 am »
Your not alone. I currently play music with XMplay with WASAPI output because it sounds better then the last generation builds of xxplay (sorry Peter).
Not to criticise XXPlayer, but would you try XMplay as well to discuss differences in SQ between those engines.
Asus-VM-htpc&1TB>EMU1212M>Stello 220MKII DAC>UCD180HXR>Focal1037BE
« Reply #6 on: April 01, 2008, 09:21:48 am »
I already did that, but it doesn't play in Exclusive Mode with my soundcard (and it sounded "grey" in the mean time).
« Reply #7 on: April 01, 2008, 10:20:21 am »
hybride,
I have been thinking ...
What do you hear as a main difference beteen 0.9u-8 and 0.9u-10 ? Or if not 0.9-8 which you compare to, which version is that ?
If you can describe it, I can easily put back what should make that difference, and then you can try again ...
For you too counts, that checking the Mem checkbox should go back to "the" old situation ...
hybride
« Reply #8 on: April 01, 2008, 11:37:03 am »
I always update XXplayer when you present a new build. So i installed 0.9u-10 at the moment.
I did not do a A-B comparisons between different builds. I will do that tonight. i'll will try the 'mem' box as well.
I only stream at 16/44.1 and play with the settings Q1 and invert.
Better in this case is not an easy thing to explain and bescribe.
between 0.9u-10 and XMplay>WASAPI@EXCL_mode the last sound more musical, softer and less harsch.
Instruments sounds more real, more enjoying the consonance.
XXplayer (0.9u-10) sounds scharper with a bit more dynamics. In my setup it is a disadvantage to enjoy music.
hybride
« Reply #9 on: April 01, 2008, 12:19:38 pm »
Mayby you should try a 18 dollar Cmedia with Dogber driver  Happy Wink
andy74
« Reply #10 on: April 01, 2008, 10:42:20 pm »
Priorities are both set to nothing, Q1=14, no invert, no upsample, 16/44.1, Unattended, Membox unchecked.
It may sounds whatever. But I can't describe it in soundstage terms. The bass and trebles seem the same. it's other thing.
It's just that physical discomfort I start to feel. It's like the left side of my head starts to shift related to the right. there... hahaha. Not sure if it helps.
And yes it is less musical and less enjoyable as an outcome.
yes
Will try it when get back "home" tonight.
Andrey
LydMekk
« Reply #11 on: April 01, 2008, 11:23:25 pm »
This is what I call "Unconsciously gnashing of teeth syndrome"...just to NAME the thing...
Will test some more Peter, and get back to you.
andy74
« Reply #12 on: April 02, 2008, 12:51:52 am »
Yeah... it's good to be perfect...
« Reply #13 on: April 02, 2008, 05:06:07 am »
Ah ya, I think you're spot on most of the time.  My vote is for you to keep your ears in here for all our sake.
andy74
« Reply #14 on: April 02, 2008, 07:06:57 am »
I tried:
1. u-8 mem unchecked
2. u-8 mem checked
3. u-10 mem unchecked
4. u-10 mem checked
1 sounds the best of all.
In 4 checking mem box cures the situation of 3 "twisting my head", but still not as good as 1 or 2.
2 sounds less smother than 1.
As I understand In my case checking mem box shouldn't change SQ because I am listening 16/44 But it does somehow.
Andrey
Page created in 0.123 seconds with 19 queries.
