November 24, 2024, 09:51:03 pm *
Author Topic: XXHighEnd Model 0.9u-10 (solves wrong byte assignments)  (Read 7644 times)
« on: March 29, 2008, 06:44:40 pm »
It is strongly advised to not use your system without a preamp (or the pre-amp at max volume for that matter) if you or your speakers won't be able to handle a situation that e.g. the file contains wrongly formatted data or otherwise - because of which cracks may emerge with an energy beyond imagination.
  • The before version attempted to use the 16 bit domain when nothing more is needed, despite the DAC being set as having more than 16 bits; this failed for Double and Quad settings. blush1 This is solved now.
  • Since 0.9u-7 the input bit rates show properly on the Wallpaper Coverart. However, since then for MP3 nothing was shown. This has been restored.
Sorry for the inconveniences caused by the before upgrade.
Edit : Might you want to play DTS, or test with that, please download the XXEngine3.zip from this post and after unzipping put it over the XXEngine3.exe in your XX folder.
Edit2 : When you are new here, it is better to download 0.9u-6; later versions are not stable enough to the sense of playback may stop after a track has been played, or gapless not working properly.
Sorry for the inconveniences.
* XXHighEnd-09-u10.zip (1953.71 KB - downloaded 708 times.)
« Last Edit: March 31, 2008, 10:17:37 pm by PeterSt » Logged
Page created in 0.158 seconds with 19 queries.
