November 23, 2024, 03:16:09 am *
Author Topic: A general test to test all in one time - Yello  (Read 19081 times)
« on: June 06, 2007, 03:44:24 pm »
All the CDs of Yello.
It may not be your music, but if you can get hold of a CD, just grab it, rip it, and put the volume at some crazy level.
This "music" contains :
  • Synthesizers. Don't let that scare you. Not this time.
    It will unveil very interesting noises, or it just won't when things are wrong.
  • Very fresh highs. So fresh, that if something is wrong, it will GO wrong. You will hurt your ears then.
  • Sub low in about everything. I think Flag is the only CD without it.
    Might you have a subwoofer or two, you will notice that you can crank up the volume and *still* will have controlled lowwww bass.
    Also, just watch your tube amp at controlling the bass.
  • Mail voices full of timbre (note that proper timbre is one of the harder things to achieve).
  • In gerenal : room filling sound. So much, that you can't believe it's possible to play that loud without things going wrong for room anomalies.
  • Very square hence dynamic rythm&pace sounds, only perceived with fast enough amplifiers.
  • When it all works out, this "music" might glue you to your chair. If it even does when you don't like it, you'll sure know enough.
Now, I *know* when your playback chain is sort of okay, XXHighEnd will allow you to play this music with an SPL meter at the listening position with 90dB at the low end. too much !
I also know, when the player is not XXHighEnd, it will just not work. In a very damped room, a bunch of basstraps added to it, maybe.
Keep in mind : only with a nos-DAC, synthesizer music will workout as intended.
Chris V
« Reply #1 on: June 06, 2007, 05:05:39 pm »
A damn fine choice of music. I have 'Flag' and 'One Second' on vinyl. A good workout for your system
I prefer Flag as it contains that fabulous track The Race, but note Peters comments above about bass. clapping
Then to SW1X Signature DAC
ELFUEGO
« Reply #2 on: June 04, 2010, 06:57:47 pm »
Hello Peter,
The album Touch has become my favorite album. Just buy/copy it!!
It is all there! Dynamics/bass/resolution/highs etc!!
My whole family likes this album (son(9) daughter(12) and wife(dont't ask for her age:-))
And together wit XXHIGHEND??????????? You know the answer already I believe. Just amazing!!
Win 7 pro - XXhigh-end 0.9z-2 engine4,sheme3 adaptive, 2048 samples, Q1,2,3,4, = 1,0,0,0 arc prediction,player low,thread real time, SFSis 18, hi-face with 5V battery, Xindak DAC-09, Gryphon Tabu, Ensemble PA-1+Profundo.
Laptop HP nc6120 1,6Ghz.Cpu , 2,5 GB memory, Samsung Story 1,5TB.
Leon
oosterom@msn.com
« Reply #3 on: June 04, 2010, 08:18:48 pm »
I fully agree with Peter about Yello. Specially the Albums "Motion Picture" and "Touch" are worth listening to with everything in it as Peter describes.
have a great weekend folks
Leon
« Reply #4 on: June 04, 2010, 08:50:14 pm »
OH, YEAH
 whistle
Btw, Touch Yello Deluxe version also contains a DVD with a 24/48 PCM track.
« Reply #5 on: June 05, 2010, 12:05:52 am »
OH, YEAH
Guys,
Quite a resurrection from 3 years back !
But I still fall back on Yello when I want to check the "square" response.
Some people may find Touch not a real Yello album, but the more I listen to it, the better I think it "Yello" is.
It might be the best of all of them.
mowa
u are what u is
« Reply #6 on: June 05, 2010, 12:41:30 pm »
Hi Guys,
Usually i only listen to classical music with some sidesteps to some Jazz and occasionally pop music. But running through some topics i read this 1 and got interested.
I've listened all trhough the Touch album and it's quite impressive. Though i think the die-hard high volume sub bass lovers are best served. This music requires a very good hifi setup to controll the lower and lowest frequencies. sounds good !
By a fresh Windows install i lost my activation code so i listened with Foobar2000. The sound was quite direct and natural with beautifull controlled bass.
This morning with my new activation and listening the Touch album again with XXhighend the soundstage became really 3d, voices and instuments more natural. The music came to life...!!
I decided percussion though sounded genuine were actually computer or synth based.
I'm curious about some other Yello albums but for now i've enough.
After the Yello experience this morning it was time to other experiences;
Mahler symphony No.4, Conductor-Ivan Fischer, Orchestra- Budapest Festival Orchestra
Mahler symphony No.8, conductor-Michael Tilson Thomas, Orchestra-San Francisco Symphony Orchestra
Mozart-Don Giovanni, Conductor-Rene Jacobs, Orchestra-Freibruger Barockorchester (Listened only some arias)
Tchaikovsky-Piano Trio in A minor op. 50, Lang,Repin,Maisky
Out of here
(Power) Monster HDP 750G Powercenter / Ke-Lo Power cable
(Source) Windows7 Ultimate X64 on Samsung 830 series SSD 128GB, Playback drive: Samsung HD753LJ, Intel Core i5, 8G RAM (Kingston HyperX KHX1600C9D3T1K2/8GX), ASRock Z77 Pro4-M
(XXHighEnd-09-z6-1) KS: Global / Engine#4 *Adaptive Mode* / Buffer 1024 / Q1/2/3/4/5 = *1*/0/0/0/0 / Scheme-4 / Playerprio = Normal / ThreadPrio = RealTime / Dac: 24bits 96.0K (24 bit only dev.) / Services off , Running Time OSD on / Unattended
(HiFi) Standard USB cable to HRT Music Streamer II+ / QED Qunex 4S / Stax SRS 4040-II + SRM-006t II
leifchristensen
« Reply #7 on: September 13, 2010, 03:32:07 pm »
I find the album "The eye" from 2003 superb
especially:
Don turbolente
and
Distant solution
the bass is superb!
really puts my Doppenberg towers to the test@+100db
best
Leif
« Reply #8 on: September 13, 2010, 07:03:31 pm »
Whimpy !
I guess you don't have a solid house !
haha
leifchristensen
« Reply #9 on: September 13, 2010, 07:48:26 pm »
110db@1m ---100@3,5m Happy
« Reply #10 on: September 13, 2010, 07:59:29 pm »
Your horns must be leaking a bit.
Happy Happy
leifchristensen
« Reply #11 on: September 13, 2010, 08:47:33 pm »
ha-ha listen to Yello "eyes" or Heavy Hour with Misha Alperin and then we´ll se what´s leaking
if you miss something send me a mail
best
Leif
