November 23, 2024, 04:37:47 pm *
Author Topic: Spooler subsystem down?  (Read 6382 times)
Joaquin
« on: March 22, 2008, 05:07:40 pm »
Very frequently I get this when I play u6.. is there something I need to do to avoid it?
I thought you mentioned something about long time ago..
Spooler Subsystem app has stopped working..
thanks.
« Reply #1 on: March 22, 2008, 07:41:13 pm »
This is the result from your Priority settings and Vista not being able to service the -whatever service it is- anymore.
It doesn't harm (as long as you don't want to print something, in this case). The only thing which can happen is that during the moment the message is shown to you the sound starts to crackle (more and more). Just stop and start Playback in that case.
There can be many more services shutting down, and as far as my own experience goes none of them harm the system. You can end up with Windows 3.11 buttons though. evil
If you care about this (I don't) higher the Priority('s) you lowered.
Btw, the more you urge from the system, the earlier/more it happens (like e.g. 96KHz playback urges more).
