March 31, 2025, 11:46:48 pm *
Author Topic: NOS1 DAC with BlueSound Node  (Read 8590 times)
music33
« on: May 20, 2023, 09:09:27 pm »
I have a BlueSound Node and was thinking about using it as a streaming device to the Phasure DAC.  From my understanding using a USB connection isn't going to work because I can't get the Phasure drivers on the BlueSound Node OS.  Even if I could, the OS is not Windows.  The other option is to use a digital coaxial cable.  This should work as no drivers are needed.  Does the Phasure DAC have a digital coaxial input?
Any advice appreciated.  Is this a foolish endeavor.
Thanks, Dave
« Reply #1 on: May 20, 2023, 11:23:13 pm »
Hi Dave,
There's an S/PDIF (coax) connection looming in there, but not more than that, so No. sorry.
In the very first incarnation S/PDIF was there, as a kind of gadget. Then with the first upgrade I asked everyone (individually) whether they wanted to keep that connection, and 100% said No.
I should not worry too much because everything "streaming" doesn't sound too good. So the DAC might be the same, but it still won't sound good.
Page created in 0.009 seconds with 19 queries.
