November 22, 2024, 01:16:26 pm *
Author Topic: Music File does not exist ??  (Read 6500 times)
Tore
« on: October 26, 2022, 07:02:45 pm »
Hi all!
Can someone help me with this problem?
Lately there are several albums I download from Tidal that have some tracks that give this error message: Music File does not exist (see picture)
It is not posible to play theese tracks, the problem is only on XXHighEnd
Here is one album: https://listen.tidal.com/album/14267452
Tore
« Reply #1 on: October 27, 2022, 10:18:54 am »
Maybe others can try it. It works with me (already sorted out with Tore by email).
Tore, do you still have only examples from Sweden with this issue ?
Tore
« Reply #2 on: October 27, 2022, 10:34:39 am »
Peter, it happens on norwegian albums too:
https://listen.tidal.com/album/251358662
Tore
briefremarks
« Reply #3 on: November 07, 2022, 02:14:51 pm »
Tore,
I sometimes had this problem on titles with special characters.  You can try a test by renaming the file without any special characters (difficult with Swedish and Norwegian).  Give it a try--change the title to something simple and see if it plays.
XXHE version 2.11.
Tore
« Reply #4 on: November 09, 2022, 05:28:38 pm »
Ramesh, thanks for the tip.
I was going to test that but first my Stealth 3 got a reboot. Peter told me to try that but it was not helping some weeks ago.
Now, when i`m testing the album`s with the problem everyting is OK  Grin
Strange
« Reply #5 on: November 12, 2022, 02:56:51 pm »
So then the question is why the same albums work with me ...
Maybe the base of your OS (the Music Server PC) is Norwegian while mine is English and that makes a difference ?
I would not be surprised if it is the disk "format". I use normal SATA internal disks for storage (previously it included USB connected disks without issues). You ?
Tore
« Reply #6 on: November 12, 2022, 10:04:35 pm »
Peter, i think the problem is gone after rebooting the Stealth
