November 22, 2024, 04:21:47 pm *
Author Topic: RDC not connecting to XXHE all of a sudden.  (Read 5247 times)
music33
« on: October 06, 2022, 04:30:27 am »
I have a dedicated Windows 7 laptop that I use to to RDC into XXHE.  It has worked for years and even yesterday.  Today I tried and RDC ends right after I move on from the certificate dialog box.  I turned off the firewall, doesn't matter.  The laptop isn't connected to the internet, so it has no updates.  Any ideas appreciated.
Thanks, Dave
« Reply #1 on: October 06, 2022, 05:51:15 am »
Hey Dave,
Is the PC with XXHE also not connected to the internet - hence is it also guaranteed free from updates ?
Did you try to reboot the PC with XXHE ?
What's the OS of the PC with XXHE ?
music33
« Reply #2 on: October 06, 2022, 02:02:23 pm »
The PC with XXHE is the Mach II loading the OS into memory.  Whatever the default OS is the one it loads.  It is not connected to the internet.  I have rebooted both machines several times.
I need to put the graphics card back into the Mach II to help me troubleshoot.
Maybe this is red herring, but I think I closed down the computer I RDC from without disconnecting from the RDC session.  Perhaps some remnants got left over...  I usually disconnect the RDC session before I turn off the computer.
Thanks, Dave
« Reply #3 on: October 08, 2022, 09:57:49 am »
Via email we determined a failing HDD (the PC to RDC into didn't boot).
music33
« Reply #4 on: October 15, 2022, 05:09:19 am »
Yes, thank you Peter, it was the hard drive.  Many, many thanks for your quick service.  Posting my next question.
