November 23, 2024, 12:51:02 pm *
Author Topic: DTS WAV playback broken from 0.9-u4 onwards  (Read 27700 times)
« on: March 13, 2008, 01:57:07 pm »
just noticed that the "crack" detection code you incorporated in version 0.9-u4 onwards is getting triggered when trying to playback a DTS encoded wav file.
In version -u4 it comes up with a "crack detect" error window and in version -u6 the error box reads "16 bit crack detect". There are also some numbers accompanying the text.
The same files worked fine in -u3.
If there isn't an easy way around detecting whether a wav contains DTS header or not, could a checkbox be added perhaps, to disable the "crack" detection code?
cheers,
« Reply #1 on: March 13, 2008, 05:59:47 pm »
Hahahaha ... some people ... swoon
Yes, that would be logic. Never thought about it.
So what you're actually saying is that while I now at last got rid of all the file formats not playing, now I have to start recognize files which *should* not play, right ? You must be like the Australian Plague !
Well, I never looked into DTS headers so far, and maybe I shouldn't; I bet the next one you come up with is an MKV, right ? hehe
The checkbox option seems reasonable, indeed taking into account that more "just data" files could be in order.
But let me first try some other general means ...
« Last Edit: March 23, 2008, 12:27:07 pm by PeterSt » Logged
« Reply #2 on: March 23, 2008, 11:40:21 am »
Hi Peter smile
all is happiness in the land downunder once more  with the release of 0.9-u7 thankyou
The little checkbox to disable the 'crack detect' code did the trick nicely. I'd forgotten how nice some of my surround albums are .... mmmmmm
Now ... to go see if I can create some loverly Matroska files to make your hair fall out again .. LOL!
CHEERS & BEERS from the land of plenty,
BTW .. I haven't had a chance to analyse the SQ difference ( if any ) of the change from -U6 to -U7 yet, but hope to find time in next few days or so.
« Reply #3 on: March 30, 2008, 05:53:45 am »
Goedemorgen Peter,
sorry to be the bearer of bad news again, but DTS playback is problematic again in versions 0.9U-8 & 0.9U-10 ( didn't try 0.9U-9 ).
The problem lies in the DTS WAV's encoded at 24bit/48kHz. 16/44.1 ones play back OK.
With 0.9U-8 , playing back the 24/48 files results in stuttery breakup of the sound, even though my Sony processor shows itself locked on at 1536kbps and 48KHz as expected. I should also mention that the only way to get sound out at all on these files is to set Dac as 16 bit/44.1 in the settings. My normal setting of 24/96 ( or any of the other non-16 bit settings ) produce no sound at all.
With 0.9U-10, the stuttery breakup is gone, but the playback speed is now slow, and the processor confirms whats happening, as it now shows 1536kbps but at 44.1KHz. I can also have my DAC setting back to its normal 24/96 value.
Note that in each of the above versions I needed the 'crack detection' box ticked , and is to be expected, and also Vol slider is at zero, again, as to be expected.
If I'm the only one playing back these DTS encoded WAV's I'm happy to setup a shortcut to 0.9U-7 on my desktop just for these files if it's not possible to sort out the bug without affecting the other checks that are now being done, but it would be nice to have the player doing everything again.
BTW .. is ANYONE else playing back these DTS encoded WAV's ?
Thanks again Peter .. I know it must be difficult accommodating these files when you don't have a DTS decoder yourself hooked up.
PS. go Ferrari !! clapping
« Reply #4 on: March 30, 2008, 09:51:48 am »
Update:
I just tried 0.9U-9 and everything works fine for the DTS files in that version !
Hope this helps in nutting out where the problem lies.
Thanx again,
« Reply #5 on: March 30, 2008, 10:12:02 am »
G'day there Russ,
I do have 44.1/16 DTS files, but I don't have any 24 bits. So that offered link would be much appreciated (PM please). BUT :
Since indeed I have no DTS receiver, how can I see it works properly ? If I can't see it on anything, then never mind the links.
Of course your latter information is VERY useful, so I hope I can do it with that. I'll try anyway. When I think I found the culprit, I'll upload a test version in here, so keep in touch !
PS: hahaha
« Reply #6 on: March 30, 2008, 10:14:16 am »
Are you sure that counts for 48/24 just the same ? (or 24 bits in general)
« Reply #7 on: March 30, 2008, 10:23:55 am »
Btw, in any case, and from theory, it is better to try everything with the Mem checkbox checked. Did you try that ?
« Reply #8 on: March 30, 2008, 10:27:46 am »
I think I found a way to check theoretically. So if you have those links please ...
The only one I have is 44.1/16 DTS. Nothing else ...
« Reply #9 on: March 30, 2008, 10:28:46 am »
yep ... both 16/44.1 and 24/48 DTS encoded WAV's play back fine. Exhibits the same playback functionality as 0.9U-7. ie. I have my DAC set at 24/96 in the settings, with 'crack detect' ticked and Vol at zero.
Also tried some 24/96 2 channel files and they worked fine also ( but haven't had time to see if the little 'click' still occurs at start of files .. but I think I read that will stil be the case )
« Reply #10 on: March 30, 2008, 10:34:23 am »
Sorry, found some 48/16 as well. heat
« Reply #11 on: March 30, 2008, 10:38:21 am »
0.9U-9 --- Just tried it again having the 'mem' box ticked and everything played back fine just as it did when unticked ( which was how I was testing things before.
I also tried tried the 'mem' box ticked for version 0.9U-10 and it didn't help for that ie. still played slowly.
« Reply #12 on: March 30, 2008, 10:46:30 am »
This one should work better. Indeed the Mem box doesn't help (as far as I can see).
I couldn't check 24 bit files.
* XXEngine3.zip (41.82 KB - downloaded 561 times.)
« Reply #13 on: March 30, 2008, 11:20:56 am »
That new engine has restored correct 24/48 DTS encoded WAV playback with one small difference to how things occurred in 0.9U-9.
My DAC settings now need to be set at 16/44.1 instead of the 24/96 I normally have it set at. That would still be a nice to have situation rather than having to change back each time I want to play DTS files but its no real drama now.
Mem box ticked or unticked didn't seem to have any effect of these files either ie. both settings worked.
Thanks for ya quick response Peter  Happy
« Reply #14 on: March 30, 2008, 11:25:50 am »
Yeah, but ... Apart from that I will make it work as should (being : it not being necessary to set the DAC to 44.1/16), does your receiver show that it's capturing 24 bits ? I hardly can imagine that, but I also can't imagine me making 16 bits of a 24 bit file and your DTS decoding still works ...
