November 23, 2024, 03:29:31 am *
Author Topic: Playback issue of album downloaded from Tidal  (Read 4945 times)
Shreekant Somany
« on: October 06, 2021, 09:38:25 am »
I recently downloaded " La Bayadere" album which has two CD's. While CD2 plays normally, CD1 has a click sound when play is started, the track starts but there is no sound, and when its stopped there is click sound again. This is only happening inn the xxhighend, the same album works well on my Ipad download. Can anybody help.
Shreekant
shreekant
« Reply #1 on: October 06, 2021, 10:32:24 am »
Hi there Shreekant,
So far I did not run into any album from Tidal that has a problem whatsoever (OK, MQA's left aside).
Wat you could try is convert the FLAC's to WAV and retry with the WAV. You can do this via XXHighEnd or any other program which can do that.
If this does not help, you could even try to convert back to FLAC from the WAV you just created.
Shreekant Somany
« Reply #2 on: October 06, 2021, 12:05:04 pm »
The original file is in WAV. Is there a way to convert it to Flac in xxh?
Shreekant
shreekant
Shreekant Somany
« Reply #3 on: October 06, 2021, 12:07:16 pm »
I had downloaded the CD from Tidal.
shreekant
« Reply #4 on: October 07, 2021, 04:00:32 am »
Start with RightClick on the Album (Library Area).
Shreekant Somany
« Reply #5 on: October 09, 2021, 09:30:18 am »
The album La Bayadere ( 86257786) was downloaded by Arvind and on his system both CD's are playing. I have tried to reboot the xxh but even after that CD 1 starts but ther is no sound.
Shreekant
shreekant
