April 07, 2025, 10:44:04 am *
Author Topic: Display / font in unnattended  (Read 13683 times)
« Reply #15 on: August 13, 2021, 02:05:59 pm »
Fr a program which runs on an OTHER PC ?
hahaha
No.
This has to be some compatibility issue between Windows versions. You know, such screens which warn you that something is out-dated ... (but which we all accept).
Please Google the issue and try to solve it. I can't do that myself ... (as I don't have the problem). I know the question seems odd, but ...
« Reply #16 on: August 13, 2021, 11:51:04 pm »
Whatever...
« Reply #17 on: August 14, 2021, 10:57:20 am »
Whatever...
What do you mean ?
« Reply #18 on: August 14, 2021, 11:29:56 am »
For your understanding ...
The sheer fact that you shut off services in the Audio PC may mean that the other PC (the one communicating over RDC to the Audio PC) is not able to detect the properties of the screen (size) at the other end correctly. This is the only thing which comes to my mind because indeed, XXHighEnd is obviously not running on that controlling PC.
I am pretty sure (no guarantee) that if you don't shut off services (the more the better the chance) that all stays in-tact. But what to do with that.
I can't tell how this could be made more comfortable for you because I don't see / have the problem. So what it seems to come down to is that with the help of Google you start to recognize your situation and from there may "tweak". Regarding that in itself ... it probably won't bring a solution because what XXHighEnd does in the Audio PC is a kind of killing the communication. This is intentional (better SQ).
Not using RDC is a kind of solution, but in the end probably not because it requires an active video card. This is present in the Mach III but (I'd say) for most it is not present at all and then the other "remote connection" means won't work.
« Reply #19 on: August 16, 2021, 03:36:38 pm »
Peter - why do you think this problem only occurs when XX is in Unattended? it is not a problem in Attended.
P
« Reply #20 on: August 16, 2021, 06:09:05 pm »
Paul, because in that case only, Services are shut down. As said, (try to) omit that and my guess is that it will be fine. Easy to try, but it starts in Normal OS mode to set it. And this with this notice that without changes at first, in Normal OS it may happen just the same. If it does, it is easier for you to test.
Please keep in mind that shutting off Services in Normal OS takes quite a while (1-2 minutes after pressing Play for Unattended).
If I'd know how to solve it, I would obviously do it right away.
PS: You said the fix is to restart XXHighEnd. Thus, Quit by crossing away and restart, right ? Could you try what you see below (when XXHighEnd already is on screen) ? Notice that this will need a real keyboard, but if it works, I can incorporate that in the XXOSK screen.
« Reply #21 on: August 17, 2021, 11:22:16 am »
I said the fix is to restart XXHighEnd - yes thats correct. I tried Ctrl-Alt-L with XXHighend already on screen as requested but it does not work unfortunately XXHighend remains small. Only when XX is crossed out then restarted does XXHighEnd return to normal size.
P
