November 24, 2024, 12:40:11 pm *
Author Topic: XXHighEnd Model 0.9u-6 (solves Double/Quad/Upsample bugs)  (Read 8018 times)
« on: March 11, 2008, 07:53:49 pm »
It is strongly advised to not use your system without a preamp (or the pre-amp at max volume for that matter) if you or your speakers won't be able to handle a situation that e.g. the file contains wrongly formatted data or otherwise - because of which cracks may emerge with an energy beyond imagination.
With many thanks to Mani (manisandher) :
a. bugs were found influencing SQ largely related to ... see title;
b. those bugs could be solved by stupid measuring;
c. which saved ages of listening instead.
My personal opinion on the SQ improvement on Upsampling with an 18 bit DAC at least : this is the first time I hear what I always perceived from "upsampling" movies which works so very well. But don't let me placebo you ! (ok, I just did, so please try to listen with the necessary dose of honesty).
Also you're entitled to receive apologizes from me at making those programming errors. On that matter I again thank you for the honest listening as I just pointed out *and* opening your heart instead of liking something because someone else tells you should.
Additionally a bug at the available checkbox options for Double/Quad/Upsample was solved.
* XXHighEnd-09-u6.zip (1950.32 KB - downloaded 1263 times.)
