November 23, 2024, 04:54:17 pm *
Author Topic: What is the problem with 44.1/16  (Read 5863 times)
Joaquin
« on: March 10, 2008, 07:50:14 pm »
this is my first post here and I have been following this process for sometime now.. I just  noticed that you put out a new version with more fixes and changes to the sound, what exactly this phrase means?
"An unavoidable change has been applied to XXEngine3 which may influence sound for native 44.1/16 files."
because, I don't listen to anything else but 44.1/16... what exactly do you mean above? is the sound worse or better, I assume worse, being that the SQ changes from version to version most of the time..
Also, I was wondering when your software will be out of the beta cycle, as I see that a lot of people is helping you to complete it and I hope to buy it someday when the software is done.
« Reply #1 on: March 10, 2008, 10:04:21 pm »
Ho Joaquin,
When I say something like that, I only mean to say that as far as I can tell SQ might have changed, but I really don't know for the better or for the worse. That's all really.
"Assuming worse" is kind of legit, because if it is unintentional, chances are kind of 50% that it got better or worse. Of course this is a kind of negative look on things, but I can't see you'e wrongness on this.
Everything will be finished when everybody agrees upon things working out OK *and*, say, workable.
Page created in 0.174 seconds with 19 queries.
