April 09, 2025, 02:43:01 am *
Author Topic: “Set state (pause) error on pin” msg while attempting playback  (Read 4046 times)
« on: March 31, 2021, 12:15:54 pm »
While attempting playback, I’m getting the following error msg.
“ Set state (pause) error on pin”.
Tried 2 albums both attempts gave the same msg.
« Reply #1 on: March 31, 2021, 01:04:52 pm »
Hi Arvind,
Bring forward the Driver Control Panel of your DAC; at the bottom you will see an indication that streaming is not on-going.
Switch Off and On your DAC; If now "Streaming is up and running" appears, all will be fine again. Notice that you'd need to apply the procedure to switch on the DAC anyway (watch the green led inside etc.).
If this does not help, reboot the PC.
Of course the USB cable has to be connected decently as well.
« Reply #2 on: March 31, 2021, 01:22:37 pm »
Thank you so much. I think the problem was with the DAC. Everything is fine now.
