April 06, 2025, 11:08:23 pm *
Author Topic: Some MQA tracks play at low speed  (Read 7754 times)
« on: March 17, 2021, 02:17:43 pm »
There is another problem with  a few MQA tracks, some of them play at lower speed (seems like half speed). Out of the entire album a few tracks have this issue. However it’s not an issue with every MQA album.
This is not a recent problem, at first, I had noticed this a long way back, on Aqualung & Benefit albums, but I had just ignored it.
Stanray
« Reply #1 on: March 17, 2021, 03:21:45 pm »
I have a possibly related, but different issue. It's not related to Tidal/MQA, but with speed.
When I play songs from a playlist consisting of high-res and redbook tracks mixed, the next song play at double speed.
Not a mayor problem however.
Stanley
« Reply #2 on: March 17, 2021, 03:42:09 pm »
Hi Stanley,
It would be good to have an example of subsequent tracks that would copy the behavior; I have very such regularly mixed tracks in the playlist, but never run into the problem you describe. I surely can imagine it, though.
If you rather not take the effort, I am fine with that. But otherwise the example should be very literal, so indeed it would happen over here too.
« Reply #3 on: March 17, 2021, 03:46:08 pm »
Hi Arvind,
Couldn't that be the same problem as described here :  Playback jumps to next track prematurely ?
The basis for that to be the same, should be an album which is 44.1 or 48 (not higher). Are those of this issue that ?
« Reply #4 on: March 17, 2021, 04:13:22 pm »
To give an example Gretchen Parlato-Flor MQA is 24/88.2, track no 7 plays at slow speed. All other tracks are ok.
Unfortunately the Jethro Tull MQA albums, mentioned earlier, have been deleted so I don’t know their details.
Stanray
« Reply #5 on: March 17, 2021, 11:04:57 pm »
Hi Stanley,
I tried to reproduce it with some random albums, but it works fine.
As soon as I encounter this behavior again I will report it.
Thanks.
Stanley
coliny
« Reply #6 on: March 19, 2021, 07:44:35 am »
This album plays all tracks at correct speed for me.
MQA 24/88.2  bit rate 4233
Regards
Colin
Stanray
« Reply #7 on: March 29, 2021, 06:11:43 pm »
Hi Stanley,
Yesterday I compared 2 tracks: John Coltrane – My favorite things in 16-44 and in 24-192. I selected the tracks from the albums and dragged them in a playlist and pressed Play. The 16-44 played normal, but when I pressed Next, the 24-192 file plays at a high speed.
As said, it’s not a big problem, because I don’t do that very often this way, but I’m curious what is happening.
Stanley
« Reply #8 on: March 29, 2021, 06:26:32 pm »
Thank you Stanley !
Pressing Next ... was this with Attended Playback ?
Stanray
« Reply #9 on: March 29, 2021, 09:48:38 pm »
No Peter, it was UNattended. Pressing ALT-N.
Stanley
« Reply #10 on: March 30, 2021, 03:25:56 pm »
Hi Stanley,
I have the hunch that this can be related to two the same track names (file names). Thus supposed that both are named
02 - My Favorite Things
(upper and lower case does not matter, and the file extension (WAV/FLAC) also doe not matter)
that things can go wrong.
Could that be the situation ?
Stanray
« Reply #11 on: March 30, 2021, 10:36:53 pm »
Hi Stanley,
Yes Peter, that's the situation.
And when I changed the first trackname/filename (by adding a "1" at the end of the title) then the next track plays at the correct speed.
Thanks Peter, it is good to know what caused it and it now is easy to solve it.
Stanley
« Reply #12 on: March 31, 2021, 05:21:41 am »
Thank you so much for your efforts, Stanley.
I recall this situation from quite long ago, and it is not easy to solve on my side. But I will put it on the ToDo list anyway.
