November 23, 2024, 01:20:01 pm *
Author Topic: bug?  (Read 8795 times)
Ava12
Headphone Audiophile
« on: March 09, 2008, 11:28:06 pm »
Maybe someone has an idea what my problem acually is. Wink
I had this problem before and I soved it with reinstalling Windows (XP) and reripping my music.
Everytime I start my XXHE Library my CPU turns to 100% and XXHE crahes.
The XXHE 0.9t-5 demo version just works fine searching the same folder for music with the Library function.
0.9t-7 demo crashes.
0.9t-6 demo doesn't crash.
I have no idea what it could be. Sad
Ava
« Reply #1 on: March 10, 2008, 12:24:26 am »
In your XX folder, there's a file named LibraryData.txt;
What happens if you delete that (after XX has been shutdown) ?
Ava12
« Reply #2 on: March 10, 2008, 09:16:54 pm »
The same happens again Sad
« Reply #3 on: March 10, 2008, 10:06:40 pm »
If I tell you that on those matters really nothing was changed between versions you mentioned, I hope you can find something yourself ?
Ava12
« Reply #4 on: March 10, 2008, 10:20:16 pm »
Last time you had the idea that this problem could be caused by windows or another programm that indexes the files in the music folder.
Do you have an idea how I can solve this problem, if this should be the problem?
Ava
« Reply #5 on: March 10, 2008, 10:26:17 pm »
Ava,
It may sound really really stupid, but I don't have a clue. If 1, 2, 3 or however many other people would jump onto this, than I'd scratch my mind as long as it takes, but now ? I don't know where to even start scratching ...
Again, if you can tell that the behaviour changes over versions, I really hope you can make something of that.
Whatever I can do to help you ... I will. But this just puzzles me.
Btw, start TaskManager in advance, and try to see what is actually consuming the cpu ...
sorry
