April 01, 2025, 01:06:05 am *
Author Topic: ET^3  (Read 18668 times)
« Reply #15 on: February 28, 2021, 03:08:02 am »
Hi Tore/Peter,
I tried Nick’s suggestion but with 10 Mb  or even 100Mb speed the RDC connection between the Audio PC & Music server doesn’t get established.
briefremarks
« Reply #16 on: February 28, 2021, 05:28:12 pm »
I now have both the Blaxius 2.5 and the ET 3 in.  An amazing improvement.  I have never heard music like this! My setup (like Arvind) is all Phasure.   The biggest difference is in classical music.  I used to avoid some of my classical music collection, especially symphonies, because they just did not sound quite right.  Truly amazing improvement.  I'm sure I'll find some words to describe the overall combination of Blaxius 2.5 and ET 3, and probably try to separate the two.  But for now I am simply going to listen.
Thank you Peter for making music so wonderful!
Now, we just need an HDMI^3 for use on HT.
XXHE version 2.11.
Tore
« Reply #17 on: February 28, 2021, 05:39:15 pm »
To bad, i need 20 meter ET3  unhappy
« Reply #18 on: February 28, 2021, 06:37:46 pm »
That is not so bad ...
hahaha
OK, it is. But at least we can make it, if needed.
Hips - oops
Stanray
« Reply #19 on: March 02, 2021, 01:28:15 pm »
I’m tempted to try the ET^3 cable, but I have a question.
If the ET^3 ethernet cable between the musicserver pc and the audio pc has an significant effect on sound quality, what about the influence of the ethernet cable between the router and the musicserver pc? In my setup I have a separate router to establish a wireless RDC connection between a laptop (that controls the audio pc via the musicserver pc). This router _can_ be connected to the main network router by manually connect the ethernet cable if the musicserver pc needs connection to internet.
Stanley
« Reply #20 on: March 02, 2021, 05:29:33 pm »
Hey Stanley,
Well, that is too difficult to follow for me. This is not only caused by a missing word I think.
My view on the Ethernet cable between Music Server PC and router : It can't matter. I didn't try it either.
But there are more cables by now I never tried because I was quite sure it could not matter ... haha
It is not easy for me to try because of the required length here.
Stanray
« Reply #21 on: March 02, 2021, 06:51:25 pm »
Thanks Peter, that is clear.
I will have to order an ET^3 then.
Stanley
briefremarks
« Reply #22 on: March 02, 2021, 11:24:23 pm »
Stanley,
I have a set up a bit similar to yours.
- Direct PC to PC connection between music server and audio PC (ET 3);
- Second ethernet card on music server connects to switch;
- General purpose laptop connects to internet with wireless, and to the switch to allow RDC connection between laptop and music server;
- Music server has RDC connection to Audio PC;
I tested direct ethernet connection between music server and laptop as opposed to both of them connected to a switch. Did not experience any benefit.  Direct connection between music server and audio PC, even without ET 3, sounded better.
R.
XXHE version 2.11.
« Reply #23 on: March 03, 2021, 08:55:01 am »
Thank you, Ramesh.
Stanray
« Reply #24 on: March 03, 2021, 12:20:08 pm »
Stanley,
R.
Thank you Ramesh, I'm curious how the ET^3 will perform in my setup.
Stanley
