November 23, 2024, 02:12:29 am *
Author Topic: Remote Desktop issues with Certificate  (Read 6319 times)
Robert
« on: January 18, 2021, 11:53:38 pm »
Since 8th Jan I get a "Remote Desktop Connection warning identity of remote computer cannot be verified.
How can I fix this?
Robert
« Last Edit: January 22, 2021, 11:34:46 pm by Robert » Logged
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
briefremarks
« Reply #1 on: January 20, 2021, 03:42:46 am »
Robert,
Some of us have had problems with remote desktop related if you configure the RDC connection to require a password.  I have found the connection to be much more reliable by allowing connection with a blank password.
Ramesh
XXHE version 2.11.
« Reply #2 on: January 22, 2021, 11:13:44 am »
It does work once Yes ticked despite errors.
Robert, what so you mean "despite errors" ?
Or do you mean despite the orange screen you showed ?
Anyway, I don't know and never saw it. Probably it is related to the Windows version you use on the Music Server PC (although intuitively you may think that it is your Mach III).
The advice to work without Password (if you could delete that in the first place) ... not sure whether I can agree with that. First off, no problems "with" whatsoever, secondly without password some things definitely won't work.
And Robert, you might re-attempt with a readable picture, if possible.
Robert
« Reply #3 on: January 22, 2021, 08:45:30 pm »
Sorry picture bad put a screen shot up now.
When I tick yes it connects to Ram os. Password is not a problem just the error message.
Robert
Oppo 205 UDP Dac
« Reply #4 on: January 22, 2021, 09:42:32 pm »
I've been getting that one for years, on and off.  It is a benign message and other than you needing to click something every now and then it seems harmless.  Pretty sure it is to do with the MusicServer, which I don't turn off any more so I don't get the message any more...
« Reply #5 on: January 31, 2021, 01:02:02 pm »
Anthony, yes good one. But mine is still W7 and I don't think it will happen there.
Robert
« Reply #6 on: January 31, 2021, 11:23:48 pm »
I investigated online and its a problem with remoting from a computer with a newer version of Win OS than the one being accessed (Ram OS). My Music server runs latest W10. Robert
Oppo 205 UDP Dac
« Reply #7 on: January 31, 2021, 11:50:01 pm »
That is interesting.  Thanks for letting us know.
« Reply #8 on: February 01, 2021, 02:01:14 pm »
Yes, Robert, great stuff. Thanks !
