November 27, 2024, 02:25:20 am *
Author Topic: 96/24 test file  (Read 8896 times)
LydMekk
« on: March 08, 2008, 04:46:51 am »
As you have stated that files from 2l.no is coded wrongly, I wondered if you have a link for me so I can test 24/96 material?
Most free files from e.g. Linn is only 24/48 or 16/48.
Wonder if XX->my DAC is really capable of reproducing 24/96 at the moment. And yes, the DAC itself is capable of 192/24, the soundcard only delivers 96/24.
But I can only make XX reproduce hissing when trying to play back e.g. 24/48 or 24/96 material (something that WMP 11 can do with no problem whatsoever) and my DAC connects with that datastream without problems.
Link anyone?
Leo
« Reply #1 on: March 08, 2008, 09:05:42 am »
http://itrax.com/index.php
Terje
« Reply #2 on: March 09, 2008, 10:23:21 pm »
http://mgn.musicgiants.com/
Look for "Super HD"
Audio pc-I72600 Hyperthreading 8 cores - 3,4GHz-16GB-Win7 office64 - OS and XX on SATA spinning disc - music and coverart on SATA spinning disk - HDD drives outside cabinet on Spiral Groove Strange Attractor feet
XXsetup - Device Xmos audio 2,0 output - Engine4 - ks mode=adaptive - buffer=4096 - dac is 24/192 - at 16 bit dac needs 24 - is Phasure nos1=off - allow phase alignment=off - allow format change=off - disable crack detection=off - 96 or 192KHz only=off - decode HDCD=on - Q1,2,3,4,5=30,0,0,0,0 - xQ1=1 - prossessor core app= Scheme3-playerprio=low-threadprio=realtime-clockres=0,5ms - noXTweaks - SFS=120 - Mx=120 -  SFS120mB - memory organisation=straight contiguous - max same as sfs=off - ionclude garbage coll=off - start playback during conversion=off - do not start playback at all=off - Copy to XX drive by standard=off - Stop desktop services=on - Stop remaning services=on - Stop wasapi services=on - stop all services=on - keep lan services=off - keep pan services=off - keep wifi direct services=off - use remote desktop=off - memory off at unattended=off - running time osd=off - osd text=off - as progress bar=off - dont do anything with coverart=off - show as wallpaper=off - show back=off - at attended=off - show mirrorback=on
« Reply #3 on: March 09, 2008, 10:37:22 pm »
Hi Terje,
I'm not sure whether that's the best ...
They don't tell what they do i.e. how they do it, much material is old, so how do they do *that*, and per album I can't see what I get, except it's High Definition.
So what is that ?
And what is Super HD ?
Terje
« Reply #4 on: March 14, 2008, 10:55:22 pm »
Jack Wrigley at Musicgiants sent this when I asked what their HD and Super HD formats ment. (have never tested any of their material myself)
Hd is equal to 44.1 16bit  our superHD is either 88.1 or 96/24 bit
Jack Wrigley
MusicGiants
Page created in 0.209 seconds with 19 queries.
