April 17, 2025, 11:37:23 am *
Author Topic: TIDAL: Remote server error (Unauthorized)  (Read 7537 times)
briefremarks
« on: October 29, 2020, 02:13:07 am »
All,
I just started getting the error trying to perform a Tidal Search and Stream: "Remote server returned an error (401) Unauthorized". I know some have had this in the part and it was related to a tidal login timeout.
I've tried deleting the TidalSession.dat file and restarting XXHE with no luck.  I am not prompted for a new login to Tidal, and no new TidalSession.dat file is created.
Any ways out of this that I can try before shipping the TidalSession file to Peter?
R.
XXHE version 2.11.
briefremarks
« Reply #1 on: October 29, 2020, 02:22:13 am »
Fixed now, but very odd.
I took the old TidalSession.dat file, and changed the date.  That seemed to force a login.
Not sure exactly why this worked, but Tidal  search and stream are now working again.
XXHE version 2.11.
« Reply #2 on: October 29, 2020, 04:39:47 am »
Hi Ramesh,
This seems very odd indeed. Especially this part is speaking :
... This seems like some quirk from an other direction ?
Thank you for sharing this. If others experience similar, I hope they step forward.
briefremarks
« Reply #3 on: October 29, 2020, 09:14:08 pm »
Did Tidal log out make it into 2.11?  Guessing not.
R.
XXHE version 2.11.
« Reply #4 on: October 30, 2020, 06:08:25 am »
Ramesh, no it did not.
« Reply #5 on: November 23, 2020, 01:24:49 pm »
Tried to stream some music from Tidal through XXHE  & I am getting a msg saying “Tidal could not be initialised (trial connection to Google failed)”.
I deleted the Tidal sessions file, closed & restarted XXHE but it still keeps coming. The music server is connected to the internet.
« Reply #6 on: November 23, 2020, 03:17:07 pm »
Arvind - Time to send me (email) your email address you use for Tidal, plus the Password.
To some people this regularly happens (like once per year); it happens to me too. I don't recall it from you, so I hope it is the same problem. In that the case then I can solve it for you.
« Reply #7 on: November 23, 2020, 04:50:00 pm »
Have emailed the details to you. However I don’t recall this problem in the past, I hope your solution works.
