April 01, 2025, 12:39:17 am *
Author Topic: Keeping it all on all the time vs using standby / off?  (Read 10761 times)
Tore
« on: October 04, 2020, 07:38:14 pm »
Peter, can you tell us where to find the button  Happy, i have never heard about this before.
After thinking about this "20 minute" heat up for a year, I decided to make a provision in the (XXHE) software that allows for silently playing music. USB is now active all thee time (though at a fairly low level) and the DAC is actively performing its D/A task continuously. And yes, even the amplifiers and everything is just On (IOW you won't hear a thing of this).
And then something happened I could not predict ...
 With this feature, you actually play music 24/7 and the difference - at least in my situation - is crazy. The sound is so so much more clean (more crispy, more responsive). And of course right from the first tones of music for the day. 😉
I never knew that this could make such a difference, and obviously when you play music continuously for say 8 hours, you won't notice either because it will go gradually (better).
« Reply #1 on: October 04, 2020, 11:26:03 pm »
Hi Tore, ... sorry about not being more clear about this ...
At the end of the day, you press the E from Alt-E at the shortcut Menu. This Pauses Playback.
The next day, say 18 hours later, you press Alt-P - this continues playback.
... But in between playback was always going on ...
Tore
« Reply #2 on: October 05, 2020, 10:41:00 am »
Great, thanks  smile
briefremarks
« Reply #3 on: October 05, 2020, 05:51:47 pm »
Trying to understand this more.  Currently:
- I have the Audio PC and Music PC on all the time;
- The NOS1 DAC is on all the time;
- The Orelo amps are on all the time;
- XXHE is in the state it is when Unattended playback completes.
Does the procedure mentioned improve on this because XXHE is playing all the time?
XXHE version 2.11.
« Reply #4 on: October 05, 2020, 06:14:05 pm »
secret
Yes ...
briefremarks
« Reply #5 on: October 05, 2020, 07:01:23 pm »
How many albums do you typically load in memory when you listen all day?  If I have a large selection of music to play all day, I usually play in Attended mode because I've never been sure how much can be loaded in memory--especially MQA tracks.
R.
XXHE version 2.11.
« Reply #6 on: October 05, 2020, 07:05:14 pm »
Ramesh, One. And with MQA less I suppose.
But I only listen to albums when they are new. And then one is "logic" I think. Otherwise I only play from Galleries and I take care that no more than 60 minutes or so is loaded. With Hires/MQA less (say half of normal maximum).
