April 01, 2025, 01:17:15 am *
Pages: 1 2 3 4 5 6 7 8 [9]  All
Author Topic: Lush^3  (Read 96411 times)
briefremarks
« Reply #120 on: September 30, 2021, 10:54:43 pm »
Peter, Paul:
I tried the new set up, and I was STUNNED! This is like it was going from Mach II to Mach III.  Absolutely mesmerizing.  The realism is unbelievable.  I am to shocked to even try to dissect what's going on.  Impossible to believe that a jumper change, and Q settings can do this.
I have to listen to a lot more music.  Initial impressions are that the sound is completely addictive.  Unbelievable clarity, resolution, separation, and coherence.  And really "alive", the opposite of clinical.
More listening ahead this weekend.
Ramesh
XXHE version 2.11.
Stanray
« Reply #121 on: October 01, 2021, 10:11:43 am »
I can only agree with what has been said above. A detailed, yet relaxed, “real” sound and also a more natural and integrated sound stage. Indeed, a more “right” sound.
The result is that bedtime has shifted considerably because of “yet another album”.
I am curious about a physical explanation for this phenomenon.
Thanks Peter!
Stanley
Roberto
roberherrera@gmail.com Roberto
« Reply #122 on: March 30, 2022, 07:43:43 am »
Dear Peter and friends,
I just wanted to add a little bit more about this configuration: I do find myself tapping along the rhythm of the music more often, in other words, I am enjoying more the naturalness of the musical instruments than I did before. Also I want to point out the coherence of the piano musical notes. Understanding the left hand vs right hand is more evident. Also, the dynamics. The right energy is granted for each drums stroke, and the right steady stage with magic quality crystal sound.
Happy listening!
Speakers: Martin Logan CLXs Sub: Martin Logan BF-210 Pre: Conrad Johnson ET-7 Power Amp: Conrad Johnson One Twenty SE Cable: Nordost Reference SPM speaker and Interconnect DAC: Holo May Kte Computer:Mac Pro. CD Player: Bel Canto CD2 and CD3 Power AC Line Conditioner: BPT 3.5 Signature.
« Reply #123 on: March 30, 2022, 08:57:19 am »
Hey Roberto !
I am happy to say that I still use your config, and that I probably can't get rid of it ever. It is exactly as you say : you can now literally see people's moods and intentions and how all play together.
Your config is so different from the others, that it is amazing that it can work out in the first place. Everybody should thank you deeply for finding this !
Hug,
Roberto
« Reply #124 on: March 30, 2022, 04:32:01 pm »
Thanks Peter,
I also must add that this is in my system, and perhaps might not work in yours.  The bass is not as prominent as it was with the B:W-Y, but has many good things like a well balanced frequency response from top to bottom, and has wider stage, with a truly sense of 3D. The voices are projected to the air, with more space. The harmonic texture of the voices and musical instruments are right. The dynamics are more precise, taking in care of what is happening with the song. I have more communication with the musician(s).  Thanks for this wonderful cable.
Happy listening!
« Last Edit: April 03, 2022, 10:05:14 pm by Roberto » Logged
« Reply #125 on: January 03, 2023, 09:49:46 am »
It has only be this Christmas time that the configuration from Roberto excelled even more than I already knew. This is because no matter how old the recording (OK, skip the cylinders) it just sounds like new from today with the advantage that back then they did not know about compression really. :-)
I screamed about old recordings (old hits from the 60s - begin 70s) more often, but now it is sooo profound.
It is and remains unbelievable what a USB cable can do. And that it is able to change sound in the first place ...
Roberto, I am just thanking you again. And I can't even imagine on behalf of how many more people that is.
