April 07, 2025, 05:50:01 am *
Author Topic: No Scrolling?  (Read 11703 times)
hwk
« on: May 13, 2020, 02:42:02 pm »
I noticed sadly that the scroll-wheel of my mouse (or the 2 fingers sweeping on my touch pad) have no effect in the gallery pane, nor in the other panes of the UI.
Would you please de-bug this?
For the rest: extremely fine sound quality with this version!!!
best regards, HW
Music Dedicated PC, Power: Silverstone Nightjar 300, MB: ASRock H87M Pro4 + I5 4570T + 4GB, Internal Memory: 16Gb Kingston DDR3-1333,  500Gb Crucial MX500 SSD with W10 Build 14393.0, 2x 4Tb WD 40EZRZ HDD for Music only), Soundcard: Seriously Modified Prodigy HD2 PCI Card 24 Bit/192 KHz with Amplimo's (van GooiPC), W10 10586-11 Home Edition 64bit
XXHe 2.11: KS mode: Special, Device Buffersize: 1024; Processor scheme: CORE 3-4; Player Prio: Below Normal, Threadprio: Above Normal, Clock Res.: 10 msec; HDCD on; SFS: 105.19,  Mem.Org.: Mixed Cont.; Q's=13x10,0,0,0; PE: Off, Custom: On; Playing Mode: Min.OS; XTweaks= On Indicates: "OPTIMAL": Bal.Load=45, Nervous Rate=99, rest=1  -  Sound Gear: Meridian 502 PreAmp (upgraded), 588 CD, 2x 505 MainAmp (upgraded) (all balanced driven), Speakers: Magnepan 3.5 SE, extra: Aphex 204 Aural Exciter; Cables: CD>Pre: Siltech SQ88, PC>Pre & Pre>Dedicated Headphones Class A Amplifier: John van Gent Reference+, Amplifiers>Speakers: Discovery 4; Headphones: AKG K1000 & Ultrasone Pro550 + dedicated Class A amp; Music Dedicated Power Group (copper shielded main cables + Oyade plugs) with parallel noise filter for the main-amps and PS Audio Quintet for the front-end. Analog: Micro Seiki DD33 modified, Denon301
« Reply #1 on: May 13, 2020, 02:49:52 pm »
Hey ...
Yes, I know, this is a bug I introduced close to putting 2.11 to production and I couldn't find the solution easily.
It's in that ToDo I showed (with *) ...
I will try to solve it soon.
hwk
« Reply #2 on: May 13, 2020, 03:23:49 pm »
Okay, thanks. I'll await your update
HW
« Reply #3 on: May 24, 2020, 06:40:58 pm »
This is now solved in 2.11a.
People can download this and unRAR and paste over the XX folder of the existing 2.11 version (and only 2.11 !) :
[removed - is now contained in the normal Download files]
« Last Edit: June 21, 2020, 02:05:51 pm by PeterSt » Logged
« Reply #4 on: May 24, 2020, 09:11:47 pm »
Yippee !!!!!!
Stanray
« Reply #5 on: June 04, 2020, 04:06:18 pm »
I upgraded from 2.10 to 2.11 and XXHE shows "model 2.11".
When I unRAR and paste 2.11a over 2.11 then XXHE still shows "model 2.11" and not "model 2.11a". What model number should be displayed?
Stanley
« Reply #6 on: June 04, 2020, 05:11:18 pm »
Hi there Stanley,
I'm afraid it should show 2.11a. Thus you must be doing something "wrong" ...
Stanray
« Reply #7 on: June 04, 2020, 07:23:38 pm »
This is what I did (the same as moving from 2.10 to 2.11) but it doesn't show 2.11a.
What do I miss?
Stanley
Robert
« Reply #8 on: June 04, 2020, 08:32:10 pm »
I have the same no "a" in 2.11a but scrolling works. I tried this several times and got the same result. Pasted over 2.11 as per normal.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #9 on: June 04, 2020, 11:26:11 pm »
Same here, scrolling works again. Thanks.
Beste regards,
Johan
« Reply #10 on: June 05, 2020, 11:41:56 am »
I really can't tell where it happened or what happened, but the offered download indeed does not show the a. But Scrolling works indeed (I just checked it).
Apologies for the confusion ...
Stanray
« Reply #11 on: June 05, 2020, 01:53:06 pm »
Cool!
Thanks Peter.
Stanley
hwk
« Reply #12 on: June 09, 2020, 10:23:59 am »
Thanks, Peter!
