April 05, 2025, 05:18:50 am *
Author Topic: Anticipated track end  (Read 3369 times)
fralippo
« on: May 10, 2020, 10:12:38 am »
In unattended mode I experience anticipated tracks end followed by a skip to the next one. What could I try to fix this???
The audio PC, connected via RDC, has a Intel I7 processor, slowed down to 1GHz and 8GB RAM.
I plaied a bit with the SFS values. The problem is there both with min/max set to 10.19 and with 0.39 min and 60 max.
« Reply #1 on: May 10, 2020, 12:01:22 pm »
Hi Fralippo,
The so-called Release Notes of this version, tell that I searched for this bug endlessly, but that I can't find it. And worse : this has been solved at some stage, but it sneaked in again.
As far as I can tell this only happens from album to album (so have a playlist with ten tracks from 10 different albums and it occurs after each track). So surely it happens at the end of the playlist.
If it occurs to you with an SFS of 0.39, well, then you have "noticing" ears. Of course you can hear it because a "chop off" really occurs, but this will now be so marginal that I would have difficulty in knowing. With an SFS of 10.19 it will be dead-clear alright.
And if you now tell me "but this really does not matter for chopped off length" then I have been debugging in the wrong direction ...
