April 08, 2025, 09:33:46 pm *
Author Topic: Tidal on Music Server  (Read 4487 times)
briefremarks
« on: April 12, 2020, 08:51:04 am »
Just ran into a problem I have not had before
Running XXHE 2.10c on music server.
About two hours ago, I can no longer prepare Tidal streams.  I can search, and get search results.  When I prepare streams, the preparation starts, but stops after a few seconds.  If I check the XXTemp folder, I can see that the dummy.wav is unpacked and I can see tracks listed, but no "Streams" folder.
I tried deleting the TidalSession.dat file.  But somehow it did not force a relogin into tidal.
Not quite sure how to proceed.  Any thoughts?
XXHE version 2.11.
« Reply #1 on: April 12, 2020, 11:28:25 am »
Well Ramesh, once you deleted that .dat file, and you restart XXHighEnd (but do that !) it should ask for the login data. And I think that should solve your issue to begin with ...
briefremarks
« Reply #2 on: April 12, 2020, 06:14:57 pm »
Happy Easter to all!!
After much fiddling around and frustration, the problem seems to be on the Tidal side, with some particular albums.  I just tried other albums and all works fine.  The one I had a problem with was:
Dinu Lipatti Chopin 14 Waltzes (the EMI Classics recording).
Still have a problem with it, after upgrading to 2.11, deleting the TidalSession.dat a number of times and logging in.
Ramesh
XXHE version 2.11.
« Reply #3 on: April 12, 2020, 07:58:52 pm »
Hi Ramesh - Happy Easter indeed !
Maybe you can see something in the logging (but switch on logging, and if helpful in the end at all).
