November 22, 2024, 10:03:29 pm *
Author Topic: Processor core setting  (Read 4780 times)
« on: April 06, 2020, 08:54:20 am »
After setting “All” cores in the BIOS, I want to set the number of active cores to 10/20, should I select 10 or 20 in the XXHE software?
Meanwhile I tried selecting 10 & 20, however in both case after rebooting the “use number of cores” in XXHE shows 28. I believe something is not working out right!
« Reply #1 on: April 06, 2020, 11:09:35 am »
Hi Arvind,
I now wonder ... *can* it actually work with avoiding a boot into the BASE OS ? ... so I am going to try myself (I have this working for more than a year by now, so I forgot ...  unhappy).
« Reply #2 on: April 06, 2020, 11:23:02 am »
Yes, it works with avoiding the BASE OS.
1. Put in the RAM-OS disk;
2. Go to Boot Menu and change number of cores;
3. Answer "Yes, apply at next reboot" (similar);
4. Press Apply in the down-right corner (not sure whether this is necessary but I did that);
5. Reboot (by means of the same Boot screen).
What you enter there is the number of cores. I had 20 in there, now it's 24 (for a change, maybe I will hear a difference for my 28 core processor (like yours)).
Indeed in the boot screen you'll find back the by you set number.
« Reply #3 on: April 06, 2020, 12:43:38 pm »
Step no 4 “Apply” needs to be clicked.
Yes now it stays on the number of cores selected.
Thank you so much.
« Reply #4 on: April 06, 2020, 02:00:06 pm »
Ha, OK !
Page created in 0.122 seconds with 19 queries.
