November 23, 2024, 01:27:11 am *
Author Topic: Can’t extract files from 2.11 upgrade patch zip file  (Read 3309 times)
« on: April 04, 2020, 09:46:44 am »
Hope all well with you & your family.
I am unable to extract the files from the 2.11 upgrade patch zip file, the warning message says “archive not found”.
Could you pls help me out.
« Reply #1 on: April 04, 2020, 09:55:39 am »
Hi Arvind,
This should help :
2.11 Upgrade Patch download appears to be damaged
Kind regard and I hope it doesn't go too bad over at your place ...
« Reply #2 on: April 04, 2020, 04:25:12 pm »
Ah, I see you solved it.
http://www.phasure.com/index.php?topic=4228.msg44589#msg44589
