November 23, 2024, 04:42:33 pm *
Pages: 1 2 [3]  All
Author Topic: DAC cracks without playing music  (Read 34778 times)
« Reply #30 on: March 20, 2008, 08:12:30 pm »
Hi hybride,
I assume you heard from Dogber that indeed his driver causes the problems you experience ?
It will be solved in the next release, he says.
That should make you happy !  Happy
hybride
« Reply #31 on: March 21, 2008, 04:50:51 pm »
Dogber added a handler to his driver which stops a stream whenever it is unexpectedly closed.
So now it should be save for unwanted behaviour of audioplayers/streams.
I hope it will work for me so i can safely remove my pre-amp.
But now i will think twice to do that...
Asus-VM-htpc&1TB>EMU1212M>Stello 220MKII DAC>UCD180HXR>Focal1037BE
Pages: 1 2 [3]  All
