November 27, 2024, 04:20:56 am *
Pages: [1] 2 3  All
Author Topic: DAC cracks without playing music  (Read 34825 times)
hybride
« on: March 07, 2008, 11:32:58 pm »
Is it possible to mute the DAC 100% in all cases off not playing music?
Because it is very strange that the cracks come up when i am browsing a library??
Asus-VM-htpc&1TB>EMU1212M>Stello 220MKII DAC>UCD180HXR>Focal1037BE
« Reply #1 on: March 07, 2008, 11:36:28 pm »
You mean without playing music ???
hybride
« Reply #2 on: March 07, 2008, 11:40:02 pm »
Yes, this did not happen in previous versions.
When XX is idle and i click library (upper left) then suddenly the cracks starts and won't stop till i start a song again.
Weird behaviour..
« Reply #3 on: March 07, 2008, 11:43:15 pm »
Can you please check wheter this happens after normally pressing Stop ?
(which is probably what you already did, but I want to be sure)
hybride
« Reply #4 on: March 08, 2008, 06:43:06 pm »
It happens random only when XX is in idle state. (not playing)
The exact moment the crack starts and why i can't figure out.
But it happens very often, so i hope you can solve this thing.
It seems like Eng#3 is triggered to start by something.
It feels like eng#3 is oscilating or something.
« Reply #5 on: March 08, 2008, 06:46:11 pm »
I think I said it before ?
C-media spdif
(from your sig)
« Reply #6 on: March 08, 2008, 07:32:47 pm »
... but as I said elsewhere, I will try to explicitly more shutdown the DAC after playing. So maybe awaiten that before looking for things which can be solved by me anyway.
hybride
« Reply #7 on: March 09, 2008, 02:39:10 am »
ok,
C-media or not it's caused by XX/Eng#3.
when i shutdown XX i don't happen.
« Reply #8 on: March 09, 2008, 10:21:31 am »
But you will be able to tell me a few more things I think. Ok, you just told that if XX is not running it doesn't happen. That kind of things swoon.
If you can't tell anything else and it really is random, please buy another PC yes, no matter whether it's only happening when XX is there.
On the other questions, could you please put them in their own topic ?
« Reply #9 on: March 09, 2008, 10:27:15 am »
Actually the most important for me would be whether you can copy the behaviour after the startup of XX, and never play anything.
hybride
« Reply #10 on: March 09, 2008, 04:16:37 pm »
As i can figure out untill now is that it not happens before XX has play a song with Eng#3. (restarted the pc and XX)
After playing a song with XX, even when closing XX, the crack random comes up, something when doing nothing with the pc.  Just idle, very strange! Sometimes the cracking of the DAC is a few seconds, sometimes without ending.
In idle state it can take 5 or more minutes when the DAC starts to tilt.
When load Foobar then and play een song and then exit Foobar The DAC stays quit.
So, can it be that when stopping/exit XX that the vista exclusive mode stays active in one way or another and that this causes the problem?
One thing is for sure now; this state of 'tilt' of my DAC has ruined my tweeter.
With a new DAC, new pc and new player (XX) it not easy to analyse whats exactly happens.
It is related with the use of XX (eng#3), because before using XX i never had this.
i hope we can figure it out
« Reply #11 on: March 09, 2008, 05:05:25 pm »
scratching
hybride
« Reply #12 on: March 09, 2008, 10:32:37 pm »
 love this sounds good !
Peter, I think you solved the problem with version u-5!
Excellent work!!
Since installing en playing around no mini loops or DAC Tilt's till now!
When strange behaviour occurs again, i will report it here.
« Last Edit: March 10, 2008, 09:14:09 am by hybride » Logged
hybride
« Reply #13 on: March 10, 2008, 10:15:30 am »
Yesterday i closed XX and started Theatertek to watch a movie. At the moment i loaded Theatertek my DAC tilt's again. (Tilt; is that a good word?)
Could it be a Vista bug that 'something' is 'not released right' after using it's exclusive mode? Because its only happening after the use of Eng#3.
« Reply #14 on: March 10, 2008, 10:19:20 am »
But to be clear : Is it now indeed not happening anymore within XX itself ?
Pages: [1] 2 3  All
