April 01, 2025, 01:02:14 am *
Pages: 1 2 [3]  All
Author Topic: Minority Clean  (Read 47000 times)
tempo
« Reply #30 on: May 21, 2022, 01:06:18 am »
I feel like there should be a setting to keep them active in Unattended mode...
I found my mistake. In the Keep Processes and Services boxes, I forgot to enclose them in brackets (  ). MC and LE seem to work now in Unattended Mode.
Onward to the listening tests!
Ciao,
Joseph
XXHighEnd:
Audio System:
« Reply #31 on: May 21, 2022, 05:10:40 am »
tempo
« Reply #32 on: May 21, 2022, 08:56:29 pm »
Here's the link for HB installer if you want it (I find it very useful): https://ufile.io/3pp84nqf
Hi, George,
Thanks for the direct link -- so much easier!
It's a good app and made installation seamless. No messy syntax to worry about.
Joseph
XXHighEnd:
Audio System:
tempo
« Reply #33 on: June 14, 2022, 07:29:12 pm »
First listening impressions were positive... I listened without Majority Clean and Lemonade Elitist and then with both activated... Together they removed a slight veil, which was more noticeable on some cuts than on others...
Now that they were enabled to persist in Unattended Mode, I ran the listening tests again and my impression was the same as before. This tells me that it does not matter in which mode they are active  -- Unattended or not, what I heard was the same as described earlier.
I also tried listening with MC alone and MC + LE and heard very little difference with the addition of LE. At least 99% of the benefit seemed to come from MC. At the moment, I'm really not sure if LE made any improvement at all or whether I was just imagining it. However, it did not seem to do any harm.
As usual, your impressions may vary.
Joseph
XXHighEnd:
Audio System:
tempo
« Reply #34 on: June 22, 2022, 12:59:33 am »
One final observation. Today I listened with either Majority (Minority) Clean 2.84 or Lemonade Elitest 4.4 activated, but not both together.
With only Majority Clean activated, I felt more involved with the music than with Lemonade Elitest. While LE did not degrade the music, I just found it less captivating and no longer have it set to start automatically. Sometimes less really is more.
I encourage listeners to experiment with both and draw their own conclusions.
Joseph
XXHighEnd:
Audio System:
Pages: 1 2 [3]  All
