April 01, 2025, 12:25:38 am *
Author Topic: V 2.11 an opus magnum  (Read 34115 times)
« Reply #15 on: April 14, 2020, 04:45:25 pm »
Thanks Peter, now all is ok
« Reply #16 on: September 23, 2020, 09:33:28 pm »
So, I finally got around to upgrading to 2.11. It's been a while since I've used XX, because I've been playing around with the DSP in Roon. But even so, I'm certain that 2.11 is a step up (again!) from 2.10. It sounds truly amazing.
So much so in fact that I don't have any withdrawal symptoms from having just returned the Taiko Extreme that I had on a week's loan. (You can read about that here: https://audiophilestyle.com/forums/topic/60458-taiko-extreme-my-experience/?tab=comments#comment-1081051).
Thanks so much Peter.
« Reply #17 on: September 24, 2020, 08:51:34 am »
Mani,
Interesting to hear your impressions.  The Taiko Extreme is a seriously priced piece of kit.  Were you trialling to see if you could find something better than the Mach III or was your interest more in the Roon/DSP side of things?  I fear that if I want to do Roon that I will have to get a second (non-Phasure) dac which I am reluctant to do, but sometimes I want something that is just quick and easy with Tidal but still sounds good.
I don't even have the Mach III yet...am waiting for Peter to source the 20/40 core cpus (hurry up Peter!)
« Reply #18 on: September 24, 2020, 10:00:01 am »
I wanted to know what the generally accepted current SOTA sounds like with Roon and HQPlayer. And yes, how this compares with the Mach III running XX... feeding the NOS1 in both cases.
Roon, Tidal/Qobuz do work with the NOS1. Once all set up, it's "quick and easy". The only thing you'll miss is auto sample rate switching. No big deal really, because you can set Roon to convert to and output a constant SR. It sounds pretty good really. I captured the output of the NOS1 being fed by XX, Roon, HQPlayer and Roon->HQPlayer with my RME ADI-2... and Roon (using its internal filters) stacks up pretty well. (Happy to send you the files if you're interested in taking a listen.)
Edit: Once set up, it's easy to switch between Roon for more general listening and discovering music on Tidal, and XX for more serious listening. No need of a second DAC!
OT. How's your own Opus Magnum coming on?
Robert
« Reply #19 on: September 25, 2020, 08:42:17 am »
No doubt about it 2.11 its the best.
I think the Taiko engineering wise is excellent that's mechanical, metals etc. You do have to pay lots for precision engineering, machining metals, linear power supplies etc to exacting extremes of tolerance. But in the end its the package versus the money to extract this. The Mach III's are also extremely good with 2.11. If we could put a Mach III in a Taiko case we are at the same price as the Taiko. I'm not in a position or probably never to hear a Taiko so its certainly worth putting your money into a Mach III. This is transforming sound wise. Robert
« Last Edit: September 29, 2020, 06:01:13 am by Robert » Logged
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #20 on: September 25, 2020, 01:02:06 pm »
I still have my Stealth II here too, and the difference between the Stealth II and the Mach III is massive. The Mach III 'sparkles' in comparison.
I really enjoyed having the Extreme here for a week, but can't imagine using anything other than XX for serious listening.
rudolf
« Reply #21 on: September 26, 2020, 12:34:01 pm »
Yes, I agree, soundquality is awesome. Giving me new dimensions... Thank you Peter for your work and support over all those years!!
_________________________________________________________________________________________________________________________________________
XXHighend 2.11a on Windows 8 PC (AMD A6-3650 APU 16 GB RAM)  with 2x Audioquest Jitterbug USB Filter
XXHighend: Adaptive Mode / Q1/-/3/4/5 = 4/-/0/0/0/ Q1Factor = 1 / Dev.Buffer = 256 / ClockRes = 0,5ms / Memory = Mixed/  SFS = 1,02  (max 1,02 / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 2-3 / not Switch Processors during Playback = Off/ / UnAttended  / /Stop all Services Off / Stop Desktop and Remaining Services ON/ Keep LAN =off/ Not Persist / WallPaper Off/ Minimize OS off
Advance xi-75 Amp/ Audioquest Cinnamon USB Cable/ KORG DSD-DAC 100/ ProAc biwire cables into ProAc Studio 130 Speakers
Robert
« Reply #22 on: January 31, 2021, 11:36:17 pm »
But this was not all ...
I think that most people will use Q3,4,5 at 1,1,1. Well, a week ago I suddenly heard how that now could go. This too is difficult to explain, but I'd say that everybody who uses 1,1,1, will know why he does that. And I now heard that it was not "necessary" any more.
And THAT beat all ...
This most certainly works in my setup very noticeable. I never would have thought to try this one.
I notice you have also changed some XTweaks : Balanced Load = *68* / Nervous Rate = 10 / Cool when Idle = n.a / Provide Stable Power = *1* / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable.
I've had the Stable power at "0" for some time did you intend to change this?
You are still using Custom filters as well? I'm still with Arc Predict.
Robert
Oppo 205 UDP Dac
« Reply #23 on: February 01, 2021, 01:40:13 pm »
Robert, good question !!
I changed that in my Sig yesterday, because, well, I found it in there at checking things (at 1 while my Sig said 0). Maybe that is not good at all ! But ... I suppose I am listening to that for "months" ? ... So I better let it be.
Arc Prediction with the Lush^3 is too much of it. Things are wildly "sharp" (which is good) but also tiring fairly quickly (not good). And with the Blaxius^2.5 that is even more "too much" (I tried Arc Prediction 2 days ago once again, because now Q3,4,5 at 0 but it did not last one track).
numlog
« Reply #24 on: April 20, 2021, 08:10:07 pm »
I have been in sort of DAC limbo for the last year and hadn't used XXHE  much, but just after trying out 2.11 with some ok gear and gotta say Im really impressed with it. I hadn't used it in so long I forgot how much of an improvement you can get from a player can make (well XXHE at least, not sure about others), It's nearly like changing a piece hardware.
Using KS, High SFS, long buffer and 8x arc predition and it sounds very good.
I am going to pair it with Andrea Mori's (from diyaudio) upcoming NOS R2R DAC, FIFO and clock when it's available.
At least Andrea's goal is to provide a FIFO that completely eliminates influence from the PC, so most of XXHEs ability will probably (but hopefully) will be wasted,
But I do still need a digital volume control and digital filtering, XXHE is still the best choice in this regard, so not completely wasted
PC: Ryzen 1700(Nofan), 2133MHz 2x4GB, GPU, Gigabyte A320
OS drive: Optane 16GB M.2, OS: S2019 Core,
modded PCIe SATA card + modded Juli@ XTE I2S output , Corsair Rm650x MoBo PSU, 12V CPU LPS .
« Reply #25 on: April 21, 2021, 08:54:08 am »
Hahaha, let's see !
I am really curious, so keep us informed, OK ?
Thank you for sharing !
numlog
« Reply #26 on: May 13, 2021, 02:11:18 pm »
I was wondering, are xtweaks active always when enabled or only when playing?
So for example they would influence the sound in other programs outside XXHE?
« Reply #27 on: May 13, 2021, 03:21:40 pm »
Good question ...
You'd have to assume that they change things when playing. This is already so with the processor speed and probably related (because of consistency) more.
Also, when you are not playing, it is the idea that the PC is "workable" for other tasks. This includes the manipulation within XXHighEnd itself too (like it is not really useful to load files per the slowest means possible).
