March 31, 2025, 11:37:09 pm *
Author Topic: V 2.11 an opus magnum  (Read 34112 times)
« on: April 01, 2020, 08:54:15 pm »
Peter hi,
If you went in for giving versions of HighEnd names like Google does for Android releases, I think for SQ HighEnd V2.11 should be the "Opus Magnum" release  Wink
The thing that hits first (from the very first played notes) is what is no longer part of the sound ! Distortions that hung about all over the spectrum in 2.10 have been banished... gone.
The music just flows so a beautifully, misicians are there in the room, the joy in performances is really captured so well, you can almost see the smiles on the musicians faces as they accompany each other.
Wow I was not expecting that.
Brilliant, really brilliant Peter !!
Thank you.
Ps did the cpu setting make it into the build ?
I could not see it but perhaps I need to look harder :-)
Robert
« Reply #1 on: April 01, 2020, 10:13:25 pm »
Yes I agree with you Nick. It does look like cpu setting didn't make it.
But I'm still running what you did in Bios Nick and this alone was well worth doing.
Nick did you patch over existing Xx version or do a clean install over W10? I just did a patch to to check on everything. I will run with this for now. At some point I will do a whole new install.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #2 on: April 02, 2020, 05:08:03 pm »
Thank you Nick (and Robert).
The CPU setting made it all right. This is the bottom of the Boot Into Menu (RightClick on Stop) :
« Reply #3 on: April 02, 2020, 08:01:17 pm »
Thanks Peter,
Im looking forwards to giving it a go  Happy
KnB
« Reply #4 on: April 05, 2020, 06:07:12 am »
Peter, with the new possibility with cpu setting in 2.11, should we adjust bios on the stealth lll to “use all core”, or any other adjustments?
and WOW what a BIG upgrade with the 2.11. Thank you!
« Reply #5 on: April 05, 2020, 09:25:42 am »
Kjell Narve, Yes, in the BIOS set to ALL now and let the software control the real number. And relatively easy to compare because it only requires a change of that number and a reboot (just from RAM to RAM is fine).
Btw, is *is* allowed to also set the BIOS to a lower cpu amount, but that will lower the "software" possibilities. But, it may change SQ again (I never tried with such combinations). Thus, set in BIOS the 14 native cores to e.g. 12 and then in software try 12, 10, 8 etc. (14 not available now).
Robert
« Reply #6 on: April 06, 2020, 02:45:50 am »
I've tried changing SFS from .69 to 10.19 and think I prefer it. .69 has a bassy feel about it including vocals. I find 10.69 image better and more balanced sound. Early days yet. I see you use 10.19.
I've also tried setting cores using 2.11 honestly can't tell if its any different to Nick's manual method probably the same or very close.
I only have 4 cores so set it to 3. But on checking Xx is running on 2 with this setting. Is this correct?
Robert
Oppo 205 UDP Dac
« Reply #7 on: April 06, 2020, 11:04:36 am »
Hi Robert,
My 0.69 did not last long (referring to another topic), so back to 10.19 it is.
As far as I remember, 3 cores are only available for older AMD processors, and it is my estimate that you don't have that. So it has to round down to two (which exists for both AMD and Intel).
Assumed it really is so that Nick's method comes (in effect) down to the same, is thus is the same (haha), but, you can easily change it now.
Btw, I never tried Nick's method, so I don't know for real.
« Reply #8 on: April 06, 2020, 08:32:09 pm »
I'm obviously late to this party. I'll download 2.11 tomorrow and share my thoughts then...
Peter, thanks so much for all your efforts over the years. I know that many of us wouldn't be having anywhere near as much fun listening to music if we'd never stumbled upon you and XXHE. And your following hardware offerings were the icing on the cake.
For my own part, I've never enjoyed my playback system as much as I do now. But somehow, I feel as though I know even less about what actually determines good sound than I did 12 years ago  scratching
« Reply #9 on: April 07, 2020, 08:23:47 am »
Thank you so much for all your effort in making our music interest more & more enjoyable.
2.11 is indeed amazing especially reducing the distortion levels significantly.
Thank you again.
phantomax
« Reply #10 on: April 08, 2020, 12:27:26 am »
Hello Peter,
As others have said, the new version represents a great improvement. You can notice right away and especially in passages of great sound density that now sound effortless  with greater clarity and less distortion. And although I've been enjoying a lot all this time the wait was well worth it.
Thank you and Best Regards
Maxi
Tore
« Reply #11 on: April 12, 2020, 11:28:42 am »
Hi Peter!
Thanks for XX 2.11 Peter, i`m glad you gave us this now  smile
Sound is best ever now with my new Phasure Mach 3
Tore
« Reply #12 on: April 13, 2020, 01:28:22 pm »
After a long time away from the forum, although not totally from the music, the forced confinement has seated me in the listening room more frequently.
To my surprise yesterday I found and installed the 2.11a new version. As always there is usually an improvement over the previous version and in my case it is clearly noticeable more detail and finesse. I can´t say more at this moment but I will closely follow the influence of the new possibilities, such as the change in the number of active cores.
Thanks once again Peter!
I wish you all the best
« Reply #13 on: April 14, 2020, 01:13:56 pm »
I am trying to change the number of cores to see the differences in sound. My music PC has a maximum of 12 cores (6+6) and, if for example I activate 8 cores (4+4), when I click play I see that the album is read by the 12 cores. When I return to the Boot Into... board to check how many cores are active it still say 8. Is it correct or is there some kind of error?
« Reply #14 on: April 14, 2020, 04:04:37 pm »
Hi Juan,
You seem to skip a step there, which is : check by means of TaskManager how many cores are active now. So if you had 12 (hyperthreded) in your example it should show 8. If it still shows 12 *there* something isn't working ... Esepcially not if XXHE=s Boot Menu shows the 8 after a reboot (Reboot is necessary !).
Page created in 0.015 seconds with 19 queries.
