November 23, 2024, 03:44:22 pm *
Author Topic: wishlist for future versions  (Read 9903 times)
hybride
« on: March 07, 2008, 10:50:45 pm »
- More screenspace for showing the name off the current playlist
- Recursively directory load
- drag and drop files and directorys from TC to Playlist (isn't working now)
Asus-VM-htpc&1TB>EMU1212M>Stello 220MKII DAC>UCD180HXR>Focal1037BE
« Reply #1 on: March 07, 2008, 11:35:36 pm »
What do you mean ? the combox with the Playlist Name ? otherwise I don't understand.
I can't think of anything else than drag doesn't work from Total Commander ...
Drop works ... scratching
hybride
« Reply #2 on: March 07, 2008, 11:51:05 pm »
Yes the combox (with 22 inch TFT there is a lot of lost space  Grin)
hybride
« Reply #3 on: March 07, 2008, 11:57:29 pm »
Drag works in Totalcommander with files and directorys.
Drop don't work in XX's playlist (here). Also not with windows explorer.
Should this work with XX at the moment?
I remember that i did it before with succes.. or i must be drunk then  scratching
« Reply #4 on: March 08, 2008, 09:49:06 am »
Of course it does !
You probably don't have your UAC stuff right.
Vista Users ... prepare yourselves ...
Anyway, if you receive the "blocked" icon at dragging over XX' Playlist Area, this is 100% a rights problem. Could emerge at the sending side (TC) as well. So maybere *there* you have to uplevel rights. But read the link above ...
hybride
« Reply #5 on: March 10, 2008, 09:13:40 am »
Of course it does !
(of course) you where right  Happy
After disabling UAC drop works fine.
Yeh, Yeh, i know that i have to read the f. manual before useing something new.fool
« Reply #6 on: March 10, 2008, 09:22:20 am »
Yeah, but how to rtf when there is no fm.
One of the major (copy/paste) works laying ahead of me. bored
Page created in 0.162 seconds with 19 queries.
