November 22, 2024, 09:46:55 pm *
Author Topic: Pictures not present  (Read 11789 times)
« on: April 27, 2019, 08:24:43 pm »
All,
At this moment most of the pictures (like in the Tutorials or Release Notes) won't show.
Hopefully this will be solved soon.
« Reply #1 on: May 08, 2019, 03:29:22 pm »
heat
It looks like I managed to move a main PC over here from a still 32 bits OS (dating via-via-via several OS upgrades back to even prior to the year 2000) to 64 bits.
All what seems to remain is buying a new scanner which really won't get to work with its old (though so-called) upgraded driver and control program.
« Reply #2 on: June 07, 2019, 08:23:18 am »
heat
Yeah, say that. But about a week ago I noticed this was not solved at all. It sill is not …
heatheatheat
« Reply #3 on: June 10, 2019, 12:23:03 pm »
And so I say … It should be solved now …
fralippo
« Reply #4 on: June 10, 2019, 07:52:17 pm »
Still missing here :-(
« Reply #5 on: June 11, 2019, 06:00:12 am »
Huh ?
Can you give me a link to a page with missing pictures please ?
There are several sources for pictures so maybe this is about something else now ?
swoon
Thanks !
coliny
« Reply #6 on: June 11, 2019, 07:29:24 am »
Hi Peter
For example there are no pictures in any of the remote control tutorial pages.
Colin
« Reply #7 on: June 11, 2019, 09:21:03 am »
Thank you Colin, but …
This is from my phone. I can't imagine how I can get farther away from the server. So it works all right. Or at least at the best I can check it myself.
Can you go to a PC where you can easily refresh the Browser cache ? Like Windows and Ctrl-F5 ?
Thanks a lot,
« Reply #8 on: June 11, 2019, 12:57:04 pm »
Pictures are showing here just fine.
« Reply #9 on: June 11, 2019, 01:30:17 pm »
Hey Brian - Thanks.
coliny
« Reply #10 on: June 11, 2019, 06:32:48 pm »
Pictures showing now did not have to do Ctl-F5. Perhaps the browser auto refreshed.
Colin
« Reply #11 on: June 11, 2019, 08:11:42 pm »
Thank you, Colin.
