November 23, 2024, 03:18:16 am *
Author Topic: Keep LAN Services issue  (Read 5930 times)
Beauchamp Michel
« on: March 17, 2019, 08:12:04 pm »
I need some help regarding the LAN services in MinOS mode.
I want to access music files on a Laptop which is on my network. In regular OS it works just fine. However in MinOS I can see that the Windows Explorer shows that the Network Discovery feature is turned off. If I turn it on it gets immediately turned off. If I simply go back to regular OS the Laptop gets discovered again.
In the XXHE Services the 'Keep LAN Services' and 'Persist' are turned on.
Would you have a clue?
Michael_B
« Reply #1 on: March 17, 2019, 09:13:24 pm »
Hi Michael,
It is not supposed to work the way you "want".
Dedicate Drive Letters to sources you want in Normal OS and use them later in MinOS. You can't access random data in MinOS Mode because it would defeat the purpose of "being lean".
Beauchamp Michel
« Reply #2 on: March 17, 2019, 11:54:27 pm »
Your answer made me think of something I had stupidly overlooked. It now works.
Michael
