November 23, 2024, 09:32:42 pm *
Pages: 1 [2] 3  All
Author Topic: 0dB cracks at -24dB volume ?  (Read 36875 times)
hybride
« Reply #15 on: March 05, 2008, 06:27:00 pm »
Well, while waiting for a new tweeter i bought some oldies for the meantime (and for testing XX ); Tannoy 611 MKII.
This oldies do not sound bad.
Well Peter, now i have to wait for an update of XX, with more security checks for wrong audiocode.
Plz. can you give this item some priority..
Asus-VM-htpc&1TB>EMU1212M>Stello 220MKII DAC>UCD180HXR>Focal1037BE
« Reply #16 on: March 05, 2008, 07:14:59 pm »
I'm working on that since hybride. Some "interesting" things came up though. I will report on that soon.
hybride
« Reply #17 on: March 05, 2008, 09:48:04 pm »
Last hours playing with a pre-amp and XX at 0db.
The problems i had with my DAC seen to be gone.
Sometimes some mini-loops, but no cracking DAC for this moment.
Peter, the problems i had could also be related to the digital volume code.
« Reply #18 on: March 05, 2008, 10:00:55 pm »
Quite impossible.
You can test that though by playing at e.g. -6dB with the preamp attenuating (a little less opposed to 0dB).
Just in case, please be careful.
hybride
« Reply #19 on: March 05, 2008, 10:10:07 pm »
Quite impossible.
Your right... The crackling just came up. Noting to do with volume.
« Reply #20 on: March 05, 2008, 10:56:52 pm »
Can you please try to explain as exactly as possible
- what you are playing (title) incl. subsequent tracks and where it happens;
- Messages which may popup (with message content please);
- File types (like 96/24) you think the subsequent tracks are;
- The DAC settings in XX (DAC is and DAC Needs).
- Whether it's repeatable (always start at the previous track where things were OK from the beginning).
Thanks !
hybride
« Reply #21 on: March 06, 2008, 05:20:34 pm »
As i remember it happens at the end of a song, a few moments after the music is fading out.
But ill will try to answer all your question. I will take some time.
hybride
« Reply #22 on: March 06, 2008, 09:58:17 pm »
This is a flac song from Eva Cassidy
The slider is at +- 75% when the song is finished?
At 80% the cracks begin and continue untill pressing stop.
Dac is at 16/96
Action is repeatable
You see 2 errors. After a while its also popups length error
« Reply #23 on: March 06, 2008, 10:02:48 pm »
a. If this is Vista, this looks like a case of numerous services shut down. By itself this is no problem, but when they do during playing, it can cause cracks (less to worse. ending up in bad).
b. Those tracks with the same length (time) sure don't look right. I.e. this looks like trouble. How do you do that ? Can you repeat *that* ?
hybride
« Reply #24 on: March 06, 2008, 10:06:00 pm »
hmm i didn't see that! I'll try to load the playlist again and see if this is repeatable.
hybride
« Reply #25 on: March 06, 2008, 10:12:47 pm »
This error appears when loading a few files to the playlist.
The files are loaded on the playlist through the errors.
Well this causes files to be loaded with the wrong filesize
Could that be the reason for the strange behaviour off XX?
hybride
« Reply #26 on: March 06, 2008, 10:24:37 pm »
Peter, i found something out.
The length error has something to do with the flac codec. I transcoded the files again with media coder and then there is no length error when loading to the playlist
« Reply #27 on: March 06, 2008, 10:41:10 pm »
I have had such file's (cd's) too... They did play after pushing the errors away.... The cd's i really liked i converted to WAV and than there seems to be no problem...
hybride
« Reply #28 on: March 06, 2008, 10:48:02 pm »
hi Gerard,
Well, thats a good (temperaly) solution for a few cd's . i hope i don't have to convert 500 gb flac files back to WAV.
What i don't understand that there can be differences in flac files. In other words why recoding Flac to Flac solves problems with XX.
« Reply #29 on: March 06, 2008, 10:52:20 pm »
Internally they are decoded to WAV anyway, but apparently something is kind of officially wrong in your "originals" ?
They are 44.1/16 ?
Pages: 1 [2] 3  All
Page created in 0.113 seconds with 19 queries.
