November 24, 2024, 07:10:32 am *
Author Topic: XXHighEnd Model 0.9u-3 (solves No track given and wrong time positioning)  (Read 7612 times)
« on: March 03, 2008, 02:10:14 am »
It is strongly advised to not use your system without a preamp (or the pre-amp at max volume for that matter) if you or your speakers won't be able to handle a situation that e.g. the file contains wrongly formatted data or otherwise - because of which cracks may emerge with an energy beyond imagination.
As the reports of today show, 0.9u-2 would play only one track at Attended Playback Mode, ending with the message "No track given" (and two more messages). If all is right, this has been solved.
Similarly, changing the time position slider during Attended Playback resulted in the wrong time point commence of playback. This too, has been solved.
Because of all the combinations (where all is related to sample rate and bit depth), mainly the first mentioned above took quite some hours of testing tonight. It looks like all was captured now (while before the impact of this was just forgotten, *and* was not applicable to UnAttended Playback which was used lately only, for SQ tests).
While severe testing may take longer than tonight only, it looked like better to have a possible 90% only solution for something which doesn't work at all with 0.9u-2 (which honestly looks more like not working since 0.9u-1).
Untested too, is the now explicit support for 48000/16 as well as 48000/16 with "DAC is" at 32 bits.
* XXHighEnd-09-u3.zip (1334.57 KB - downloaded 735 times.)
« Last Edit: March 03, 2008, 07:58:40 pm by PeterSt » Logged
Page created in 0.113 seconds with 19 queries.
