November 22, 2024, 11:54:04 pm *
Author Topic: Audio PC doesn't see Phasure NOS1  (Read 21923 times)
Stanray
« Reply #15 on: February 16, 2019, 03:15:01 pm »
The normal procedure with NOS1a/G3 is :
- Boot PC (if that was necessary for some reason);
- NOS1a/G3 does not connect;
- Switch Off NOS1a/G3 and switch On - connects now;
- DC Offset is now wrong, so witch Off/On with Switch#2.
This is 100% standard. Leave out the switch Off of the NOS1a/G3 and nothing works.
And then still something can be with your Lush^2 ...
Yes, this is the procedure I followed many times and all cables I have will connect, but not my Lush^2.  Sad
Stanley
« Reply #16 on: February 16, 2019, 04:10:12 pm »
Stanley, does it help if you connect all the wire at both sides ?
(I expect not)
And otherwise it is time to send it over. I suppose it can happen something is wrong, never mind we test them all (happened one time before).
Stanray
« Reply #17 on: February 16, 2019, 05:27:51 pm »
(I expect not)
No that did't help, BUT when I DISconnected all the wires at both ends, the connection was made.
And when I REconnected the wires, while leaving the cable attached at both sides, the connection remains.
However, for me this an awkward procedure to make the connection, because the B-connector at the NOS side is very hard to reach and see in my setup.
Stanley
« Reply #18 on: February 16, 2019, 06:01:24 pm »
Stanley, then I am afraid you have an other kind of issue. Some groundloop thing somehow. Try whether Switch#3 on your NOS1a/G3 matters. But generally, wheter a different Protective Earthing helps.
We could also send you an other Lush^2 to see whether that helps, but ...
Stanray
« Reply #19 on: February 16, 2019, 09:22:57 pm »
Once the connection is established, I can reboot as many times as I like and the connection remains. Only after a longer period (say several days) it becomes harder to make the connection.
Something to do with grounding, potential differences, static electricity?
For now I'm fine, if the problem persists I can always try another Lush^2.
Thank you!
Stanley
« Reply #20 on: February 17, 2019, 12:23:12 pm »
I am thinking of the build-up of capacitance. It could be similar to "us" needing to reboot the PC once in a while in order to sustain a good SQ. I don't know ...
Does your DC-Offset remain the same throughout the days ? you could check each day before a first play session.
« Reply #21 on: February 17, 2019, 07:17:44 pm »
Gents,
Your issue is proberbly nothing to do with this but I mention it as was unexpected and therefore a difficult intermittent problem to find.
Some time ago I had periods were it was difficult to connect my PC to the NOS1, also periodically the connection would drop or I would get a high number of usb transmission errors whilst playing music, usually when bass notes were struck. Finally SQ was just not consistent session to session.
It drove me mad. I was doing some very complex stuff in my PC at the time with countless iterations and listening sessions. I just could understand the variability in SQ I was encountering.
Won't bother you with how the issue was isolated, but it turned out to be the short USB cable on my NOS1. Once it was pinpointed I put a meter on the short USB d+ and d- pins. The resistance was all over the place anything from 100 ohms to a few K ohms ! The culprit was the moulded connector at the small end of the cable. Move the cable near the connector and the resistance went anywhere.
The attached pic shows the cheap replacement cable I made up. The new cable stopped all sorts of SQ and connection vairiability problems including some PC to NOS1 USB cables being better at connecting than others.
Stanley
A as mentioned above your problem most proberbly not the same but it might be worth replacing your short cable with a spare just to rule this out.
Kind Regards,
Stanray
« Reply #22 on: February 18, 2019, 09:21:25 am »
I will check the DC-offset in the coming period.
Thanks Peter!
Stanray
« Reply #23 on: February 18, 2019, 09:25:16 am »
Hi Nick,
Thanks for your reaction, and I will try your suggestion and try another short cable.
I'll keep you informed.
Stanley
