November 22, 2024, 06:23:31 pm *
Author Topic: Correct settings in xtweaks to clock down the microprocessor  (Read 4552 times)
listening
« on: November 17, 2018, 04:50:02 pm »
what is the correct setup of XXHighend version 2.10 to underclock the microprocessor to 500 or 600 MHz?
The base processor clock frequency is underclocked to 1200 MHz via BIOS.
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #1 on: November 17, 2018, 05:37:24 pm »
Hi Georg,
See my sig for the XTweaks settings. Maybe look at the "General PC settings" because they don't address the necessary cooling for the Mach PC's. The main one will be Balanced Load (and above 42 for a normal processor like yours).
It is not guaranteed that it will work, but I have the idea that it can work for all, if it is only understood.
Set it in Normal OS. Boot to MinOS. Play Unattended a few seconds. And maybe after that reboot one time. If then it doesn't work well under 1200MHz right from booting, then, well, it doesn't work.
Over here it always works out of the box, BUT I always use the RAM-OS Disk as a base (I mean : for any new PC we build).
