November 22, 2024, 06:02:30 pm *
Author Topic: Installing XXHighend Error  (Read 16347 times)
« Reply #15 on: November 17, 2018, 11:55:04 am »
Thank you Georg.
And really no problem to spend that time. I wish that would not have happened. Is it the Ryzen indeed you are using there ?
listening
« Reply #16 on: November 17, 2018, 04:03:55 pm »
No, it's an Intel® Core™ i7-6800K Processor. I'm always some generations behind ...
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
listening
« Reply #17 on: November 17, 2018, 04:26:54 pm »
The following actions did work here for the fresh installation of Windows 10 and XXHighend:
  • Determine the market launch of the microprocessor
  • Choose a Windows 10 version, which came later to the market
  • Disconnect network connections
  • Install Windows 10
  • Disable Windows defender
  • Install .NET 3.5 from Windows DVD
  • Download XXHighend Version from 2.07 up (better the last version)
  • Copy XXHighend Version to suitable directory and setup
  • Set UAC to optimized XXHighend usage
  • Click to Stop W10 Updates
  • Set back UAC to normal
  • Activate
Something went wrong when stopping W10 updates fails. In my case I installed a too old version of W10.
Georg
-> SMSL SU-8 ES9038
