November 22, 2024, 05:23:56 pm *
Author Topic: Installing XXHighend Error  (Read 16337 times)
listening
« on: November 11, 2018, 12:08:50 pm »
Hi Peter, hi all,
I'm setting up a new PC with core I7 6800K processor / 16 GByte RAM and run into trouble.
Constraints:
Fresh installation of Windows 10 N 1511
Windows Defender off
.NET 3.5 installed
XXHighend 2.10
No manipulation of Windows 10 whatever
XXHighend 2.10 copied under C:\XXHighend
Starting XXHighend and got he following messages
I tried to add preset files from the other PC into XXData directory and could select one. After leaving XXHighend and starting again I run into the setup procedure again.
Any ideas?
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #1 on: November 11, 2018, 08:02:10 pm »
Hi Georg,
Maybe it is so that the .exe files in your XX folder are "blocked" (see properties of the files) ?
In this case it would be about ChangeWP.exe.
If that is not so ... can you change the Wallpaper (like with rightclick on the Desktop etc.) ? If your Windows is not activated your answer will probably be "No", but in that case I don't know whether it influences. This is because you probably have a Windows 10 version which is (may not be) compatible. If you go to a Command Prompt and type Winver in there, what version / build does it come up with ? The N 1511 does not ring a bell really, but it looks to be an older one (maybe even provided by me).
listening
« Reply #2 on: November 11, 2018, 09:02:18 pm »
the files are not blocked. Unfortunately the ChangeWP.exe  is not included in the rar-file.
The wallpaper cannot actually be changed - the OS ist not activated. I'm using the version you provided: Version 1511 (OS Build 10586.0) W10 Pro N.
Georg
-> SMSL SU-8 ES9038
« Reply #3 on: November 12, 2018, 08:03:00 am »
Hi Georg. I'm afraid then that is your problem, because it is ...
I just checked it (downloaded 2.10 main file (first listed in the 2.10 topic) myself and unpacked) and it just is there.
Maybe some anti virus after all ?
Or maybe it got deleted by whatever accident ?
My suggestion is to re-download the .rar and retry ...
listening
« Reply #4 on: November 12, 2018, 09:07:01 pm »
the file was silently quarantined  by the antivirus program off the PC where I downloaded the rar-file to. Installation is without errors yet. But there is another message, that there is only a half attempt of disabling windows update using the Stop button. What could be the reason?
Georg
-> SMSL SU-8 ES9038
« Reply #5 on: November 13, 2018, 04:10:52 am »
OK Georg, good.
Not sure. But also not sure what the "half attempt" could be you are referring to. What do you notice of it ? Or maybe better : what does it mean, "half attempt" ?
listening
« Reply #6 on: November 13, 2018, 09:25:14 am »
attached is the whole sequence.
Georg
-> SMSL SU-8 ES9038
« Reply #7 on: November 13, 2018, 10:50:03 am »
Georg - Thanks.
I wonder whether this can be related to not having shut off the UAC yet. Maybe you already did, but ...
I have never seen this before (but obviously I anticipate it).
If you never connect this PC to the Internet, it won't be a problem anyway ? (let me know your thoughts)
listening
« Reply #8 on: November 13, 2018, 10:56:16 am »
I did a fresh W10 and XXHighend installation without shut off the UAC. Didn't I think of something?
Georg
-> SMSL SU-8 ES9038
« Reply #9 on: November 13, 2018, 11:58:58 am »
Haha, no ... ME (perhaps). This shut off UAC as how it works today, works like that since 2.10. So what I meant is : maybe I made a mistake and it is necessary to shut off the UAC. Mind you, via the Stop button again. Thus :
- Shut off UAC;
- Stop Windows Updates.
In that sequence.
No need to reinstall anything. Just stop UAC and retry the Windows Update thing.
Does not help ?
Then swith on logging, retry the Stop Updates and right after the last message about it (see your earlier post) grab the newest XX- (thus only XX-) log file and post it (or send it to me, what you like best).
listening
« Reply #10 on: November 13, 2018, 03:16:04 pm »
Did not work. Logfile is attached.
Georg
* XX-20160705-150630.log (0.57 KB - downloaded 381 times.)
-> SMSL SU-8 ES9038
« Reply #11 on: November 13, 2018, 05:53:21 pm »
Georg, why did I think about asking you to switch on logging, quit and restart XXHighEnd and then apply the procedure with the log file, but did I not ask you for real ...
Now I lack data which could be useful.
It can very well be that I built in something for 10586.0 which was not tested and maybe does not work now.
Were you previously using 10586.0 with 2.10 ?
listening
« Reply #12 on: November 13, 2018, 06:14:13 pm »
I misunderstood, sorry. Should I log the sequence again? Additionally I got the attached message when "Set UAC to optimized ..."
Yes, I'm using Version 10586.0 on the other music PC. It's AMD based.
Georg
-> SMSL SU-8 ES9038
« Reply #13 on: November 14, 2018, 11:23:49 am »
Hi Georg,
Would it be fair to say that something is wrong ?
Did you unpack the whole .rar on a not "AV infected" PC and did the install all over (of XXHighEnd) ?
Could that AMD be a Ryzen ?
Yes, if you still feel the lust ... Happy
PS: Strange suggestion perhaps : why stay on 10586.0 ? I don't think many people stil use it and at least for me it certainly doesn't sound better. I am thinking of this because *if* that is a Ryzen, you wouldn't want to use a too old OS. 14393.0 may not even cut it, but we haven't really tried newer builds anyway ...
listening
« Reply #14 on: November 16, 2018, 10:22:25 pm »
installed build 14393.0 with success. There is a correlation between the processor type, the version of Windows 10 and the XXHighend version. It is probably necessary to use an operating system version that has a version date similar to the microprocessor's market launch.
Thank's a lot for spending your time.
Georg
-> SMSL SU-8 ES9038
