November 22, 2024, 08:42:26 pm *
Author Topic: error when opening xxhe, stuck in minimized OS.  (Read 10930 times)
numlog
« on: October 18, 2018, 02:06:17 pm »
I finally started experimenting with the xtweak settings and was blown away, I tried to go to previous track with alt+v (not sure if thats the right command) and it closed, now opening gives the error:
Save or Load - Error at intializing: Value of '49' is not valid for 'Value'. 'Value' should be between 'Minimum' and 'Maximum'.
parameter name: Value Setting: 010
after clicking ok on this another error pops up:
Load Settings - An error occured loading settings
doy you want to load previously autosaved preset settings file
clicking yes and selected any of the files gives the same error.
I would reinstall XXHE but im stuck in minimizedOS, not sure what the best thing to do is
balanced load of 80 and nervous 99 was the current xtweak settings but this was also first time I pressed the alt+V shortcut
PC: Ryzen 1700(Nofan), 2133MHz 2x4GB, GPU, Gigabyte A320
OS drive: Optane 16GB M.2, OS: S2019 Core,
modded PCIe SATA card + modded Juli@ XTE I2S output , Corsair Rm650x MoBo PSU, 12V CPU LPS .
« Reply #1 on: October 18, 2018, 02:24:25 pm »
Hi Numlog,
You just caught me at a bad time - namely UPS shipping time. And this is something to really dive into.
What I would do in this case, is locating that settings file (you wanted to revert to, say the one from yesterday), have XXHighEnd not running, and put that file in the place of PresetLoader.XXSI in your XX folder. Thus, ditch the old one (or save it under an other name) and put the backup in its place with the PreselLoader.XXSI name.
Now restart XXHighEnd.
I am not really sure why the normal procedure (of restoring that file) does not work, but I do know that the initialization of what this is about is one of the very first things which happen hat the startup. Read :
Your little exercise for this morning may not help a thing. Still it is the only thing I can come up with, without the real time for it at hand.
So later ...
numlog
« Reply #2 on: October 18, 2018, 02:40:16 pm »
Hi Numlog,
So later ...
no luck with that but there is no rush.
« Reply #3 on: October 18, 2018, 04:13:31 pm »
OK, this is too difficult. Can you prepare a TeamViewer connection ?
This can be to the Audio PC itself, assumed you did not shut off the LAN all the way, or to a Remote (RDC) you are uwing to control the Audio PC (where XXHighEnd runs).
« Reply #4 on: October 18, 2018, 04:14:22 pm »
If you can, you can send the inlog details to my email address.
« Reply #5 on: December 05, 2018, 11:00:00 am »
I have a similar problem.
After changing some settings a restart keeps giving the attached errormessage.
This time with errorcode 121.
Replacing the XXSI file does not help.
Maybe a fresh install is needed?
Gerard.
« Reply #6 on: December 06, 2018, 06:40:46 pm »
Hi Gerard,
If I tell you that this is related to showing the Wallpaper Coverart, would you be able to tell me what you changed in that realm ?
« Reply #7 on: December 06, 2018, 09:26:18 pm »
If I recall properly I turned it on because it did not show.
BTW I play in maximized mode, attended.
I'm sorry that I can not be of more help because the program does not start anymore. unhappy
« Reply #8 on: December 07, 2018, 03:58:20 pm »
Maybe ChangeWP.exe is "blocked" ?
(see rightclick on that file, first tab - example below)
« Reply #9 on: December 07, 2018, 06:43:38 pm »
ChangeWP.exe was missing! nea
After putting an old version back the activation was gone.
Putting in the 2.10 version trips the Avast virus scanner! unhappy
« Reply #10 on: December 08, 2018, 09:59:56 am »
Hi Gerard,
Recall someone else had the exact same problem; ChangeWP.exe was simply not "extracted" from the .rar (because of virus detect again ?)
This XXHighEnd version is adjusted such that it won't be seen as having a virus. Notice though that this is XXHighEnd.exe only and that this thus replaces the XXHighEnd.exe which will currently let trip your virus scanner.
