April 02, 2025, 10:08:05 am *
Pages: 1 2 3 4 [5] 6 7 8 9  All
Author Topic: The greatest invention in/for Audio (Lush^2)  (Read 146190 times)
briefremarks
« Reply #60 on: January 22, 2019, 06:29:35 am »
Nick,
Have been listening with A: B-W-Y-R and B: B-W-Y this evening, especially to classical music--Bruckner particularly.  Really nice.  At least for this music, I think I prefer this setting to B: B-W-R.
Good find.
Ramesh
XXHE version 2.11.
briefremarks
« Reply #61 on: January 22, 2019, 07:11:32 am »
After listening some more, and switching to Charlie Haden Tokyo Adagio, I think B:B-W-Y sounds a little unnatural--too many "resonances" and echoes.  More listening needed.
XXHE version 2.11.
« Reply #62 on: January 22, 2019, 08:25:35 pm »
Ramesh hi,
I think I might be able to understand your impressions so far. Extrapolating from listening to Manis system last week (Stealth III, blaxius^2 B:B,W,R) I can understand how the B:B,W,Y could sound a bit etched and forward:
The blaxius^2 is VERY transparent and introduces a life and a joy de vivre to the sound (I will be ordering a set as I just can't listen to my system easily since hearing the cables at Manis  unhappy ).
The Stealth III is more prone to mid / upper mid resonances than my PC.
I suspect that B: B,W,Y "works" here at the moment because this setting in part overcomes the relative darkness of my Blaxius 1 and my PC dosent reinforce the more forward presentation.
I am really looking forwads to listening again when I have Blaxius^2s in my system. For sure I know that I cannot reliably do more work on my PC or Lush^2 settings until the the cables are in.
Thanks for feeding back your thoughts. Its going to be fun seeing if my Lush^2 settings need to change with the introduction on the new cables.
« Reply #63 on: January 23, 2019, 12:04:11 pm »
All,
Today I will be into my 6th day of
A:B-Y, B:
(indeed nothing connected on the B side)
I keep on explicitly noticing how natural this one is. Detail is still exhorbitant, width is normal, depth is again relatively shallow. I suppose this latter contributes to "naturalness". And if my theory hols that sound should not be spread too much (like the width is OK now) then a bit of less depth may encourage accuracy ? (naturalness)
It won't be easy for me to take this one out again, so I am not sure when to test something new (or back to "the one with consensus" first, for that matter).
briefremarks
« Reply #64 on: January 24, 2019, 08:52:06 am »
Just tried some comparisons between the "consensus" configuration A:B-W-Y-R, B: B-W-R, and Peter's latest A: B-Y, B:.  I have to say I prefer the consensus configuration.  The new configuration sounds pleasant and detailed, but lacks dynamics and emotion.  Maybe this comes off as "natural", but it is a natural that can start to border on flat.
I tried a few more configurations, some based on the discussions on the CA forum, but none of them is better than the consensus with my system and XXHE configuration.
My only dissatisfaction with the consensus configuration is in playing dense, complex, orchestral music.  This could be a problem with classic music recordings in digital format.  Many are mastered badly.  I find the playback a bit on the harsh, scratchy side--especially trumpets and massed strings.
XXHE version 2.11.
« Reply #65 on: January 24, 2019, 07:03:46 pm »
Thank you, Ramesh !
« Reply #66 on: January 24, 2019, 07:22:13 pm »
Btw, Ramesh, it seems evident that the lower dynamics (but this is mere higher frequency stuff) cause the depth to deminish. I am just observing after I read your post ...
Quite similar to adding F-M highs to your Orelo MKII speaker (adds spaciousness).
briefremarks
« Reply #67 on: January 24, 2019, 09:13:34 pm »
In addition to the difference in HF content, there is something about the consensus configuration where the "attack" on notes: piano, drums particularly seems more accurate.  Notable listening to Keith Jarrett on piano.  One album worth using for tests is the incredible "Birds Requiem" by Dhafer Youssef
R.
XXHE version 2.11.
Rmalits
« Reply #68 on: February 07, 2019, 05:02:06 pm »
about a week ago I sent you the following email:
I felt pretty safe in Colombia, safer than in Europe somehow.
I am back in Austria now. So please have the new cable mailed to me.
I will wire you the 45€.
Thanks a lot
Richard
I don‘t know if you got this email, because I didn‘t get an answer and no new lush^2 arrived so far.
Kind regards
Richard
« Reply #69 on: February 07, 2019, 06:21:31 pm »
Hi Richard !
Hmm ... The past week I thought of this two times and on the wrong moment (like driving the car). Point is, I guess, the order is by now from 5-6 weeks or so ago (so it went out of my sight) and for the same amount of weeks you also don't transfer the 45 you mention there yourself. So there too, no trigger. And UPS just left, thus too bad again.
Btw, I also asked you to send me something (5-6 weeks ago). Nothing to be seen yet.
So ? So by now we could make it formal ... your turn first ?
haha
Kind regards and thanks,
Rmalits
« Reply #70 on: February 17, 2019, 07:45:20 pm »
after being skiing for a week in the Alps, I plugged in the new replacement Lush^2 right now.  Ohh, it´s so much better than my old (maybe too long) Lush.
Thank‘s a lot, Peter!
I feel really bad now that I haven‘t sent you back the broken one yet... and the money too...
I will do it tomorrow... promised!
Kind regards
Richard
« Reply #71 on: February 18, 2019, 03:26:25 pm »
Haha !
Thank you, Richard.
briefremarks
« Reply #72 on: March 07, 2019, 08:58:48 am »
I found the "consensus" configuration A:BWYR, B:BWR not quite right with large orchestral works.  Have been listening to A:BW&YR, B:BW for a few hours tonight.  This configuration seems better with large orchestral works.  Large string sections sound fuller, not scratchy, and somehow more coherent.  Also imaging seems more precise with placement of orchestra.  Will keep this as default for now, and come back to consensus configuration in a week or so and see how it feels.
XXHE version 2.11.
« Reply #73 on: March 09, 2019, 11:35:19 am »
A:B-W&Y-R, B:B-W
I am playing with this for something like 10 days now and I love it. Btw, this was IIRC the 2nd configuration I tried judged it as "Super Sound" but went on to a next (eager as I was last year when the Lush^2 was new). 5 weeks ago or so I announced that I should revisit this one, and so I finally did.
The reason for going there was a different one than "just do it"; I did it because I suffered from a too white sound (cymbals) and found the description to this configuration which told that the cymbals receive more color of it. Aha ...
And that worked out.
My story is more complicated than being about the Lush^2 alone (I will write a post elsewhere about this) but I am quite confident that everybody should try this config.
« Reply #74 on: March 09, 2019, 12:58:23 pm »
There :
Re: Phasure Mach III Audio PC with Linear Power Supply.
