April 01, 2025, 01:16:17 am *
Pages: 1 2 3 4 5 6 7 8 [9]  All
Author Topic: The greatest invention in/for Audio (Lush^2)  (Read 146127 times)
« Reply #120 on: April 12, 2020, 07:48:24 pm »
And does it coincidentally work with all shields connected at both ends ?
Do notice that the sequence of connecting and/or switching on of devices, remains important.
PS: I hope you work in all circumstances with the same (isolating) switch setting of the ISORegen. I mean, that that's excluded from being the source of your "sudden" problems.
A hint could also be that something which is working "keeps the current flowing". Which is different from the necessity to set up this current flow; it may take different paths from the first time (long ago now) when you got it working. That switch could be an example ... change the switch position - it may start to work, and without shutting off anything, you might change the switch position and it keeps on working.
mtcs
« Reply #121 on: April 12, 2020, 09:06:09 pm »
I have only used the configuration as shipped. I will try connecting everything.
I have tried every possible power up/down permutation.
I have not changed the Isoregen switch but will give it a shot.
Thanks for the suggestions. By the way, the Lush^2 is much more enjoyable than the significantly more expensive Nordost cable.
« Reply #122 on: April 12, 2020, 09:18:42 pm »
*if* it works ...
Btw, I know of exactly *one* situation where it wouldn't work, but worked with all shields connected. Really, one only. But you seem to be more special because it workED. So in my view this has to be some environmental thing.
Please consider newly obtained stuff since you got it working in the first place (but never disconnected). This include light dimmers and the lot.
You can ask Alex C. - this all matters (but not meaning to bother him with this).
Please remember, the last time I tried, I too could not get it to work anymore, WHILE it has worked before.
And the sad thing : in some aftermath I found the possible reason ... which I thus forgot.
mtcs
« Reply #123 on: April 13, 2020, 10:26:49 pm »
Not sure why, but I got it to work.
My set up was uR=>audio quest dragonfly=>nordost usb=>isoregen=>auralic DAC. I simply hot swapped in the Lush^2 while leaving the dragonfly in the uR and the isoregen in the DAC. I got an immediate connection that continues to work.
Thanks again. Cheers.
« Reply #124 on: April 14, 2020, 04:00:13 pm »
Yea, see ? That changes the start-up sequence. In this case : first start the device(s) (they run now from the source as well as the target) and then connect the cable (it starts to push-thru right away).
Btw, leave it like this and better don't re-attempt. Haha.
Regards and thank you for the feedback.
Robert
« Reply #125 on: November 20, 2020, 03:01:01 am »
Peter taking the lead from the latest Lush 3 settings is there any reason why this would not work removing jumpers from both ends of the Lush 2.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #126 on: November 20, 2020, 12:54:03 pm »
Hi there Robert,
(this is about this configuration of the Lush^3 :Re: Lush^3).
No, I don't think you will find much resemblance with the Lush^3, in your Lush^2 with this confuguration.
The Lush^3 is too differently sounding from the Lush^2 and the reason are the shields (or the extra shield). Thus, even when not connected at all, they "shield", although technically (electrically) this won't be something that a real EE will admit. For example, if I'd change the config you talk about
A:, B:
into
A:W&Y, B:
there is still no shield connected as such, BUT two shiels connect to each other (and that on one side only). This drastically changes the sound. You could try similar with your Lush^2, but I can't predict the result.
Robert
« Reply #127 on: November 23, 2020, 03:41:34 am »
I removed the shield wires from the connectors both ends and have listened all weekend. Replacing connectors today in the last config: A:B-Y & W-R, B: B-Y & W-R.
Definitely a difference and I have to say I like no shield connections and went back to this. Something about this sound that is easier, more natural, better balance from bass to vocals.
I can't compare to Lush 3 but suggest all Lush 2 owners should try this.
Robert
Oppo 205 UDP Dac
« Reply #128 on: November 23, 2020, 08:10:07 am »
Thank you very much for sharing this, Robert.
With the Lush^3 I am still on a similar "minimalistic" path, which for the Lush^2 would come down to :
A:W-R, B:W-R.
I have to say I like no jumpers and went back to this
In order to avoid misunderstanding, with that you mean "no wires at all connected".
The jumpers are the little black pieces (in my terminology).
N.b.: In the A:, B: situation, one could also attest that the 5-pin connector(s) are not even there.
Robert
« Reply #129 on: November 23, 2020, 09:06:53 am »
Yes no wires connected. Forgot the black jumpers wasn't using them.
Oppo 205 UDP Dac
